Not be able to access grass map
Malcolm Williamson
malcolm at cast.uark.edu
Wed Oct 16 18:18:07 EDT 1996
Hi, Seugchan
It sounds like your current region is set incorrectly, so that your map
data is not in its "field of vision". Try:
g.region rast=name_of_one_of_your_layers
d.erase
d.rast same_raster_layer_name
The other possibility is that you have a mask turned on. Do a
g.remove MASK
and see if it actually removes anything. This is something that very
experienced GRASS users still get caught on now and then! (I know this
first hand...)
Good luck,
-Malcolm Williamson
On Wed, 16 Oct 1996, Seungchan Kim wrote:
> Hi, grass users!
> I'm a novice in grass world, and got in trouble.
> The trouble is that I could not access any map in the mapset.
> I can see map files (just see), but whenever I was trying to
> access those map files, I got zero values. Of course, I could
> access those maps before, but from this afternoon I could not
> do anything with the map files.
> Please help me. I must do something until Thursday.
> Seungchan Kim (dolchan at agen.tamu.edu) |=|
> 315 Scoates Hall ~~~~~~~~~~~~~~~~~~~ (o o) ~~ 4302 College Main #369
> Agricultural Engineering Department ( ^ ) Bryan, TX 77801
> Texas A&M University _|"|_ (409) 260-3051 (Home)
> College Station, TX 77843-2117 /_\*/_\
> (409)845-4076(Office) -=-=+=-=- (URL)http://www.agen.tamu.edu/~dolchan
