GRASS on Origin 2000
Chuck Ehlschlaeger
chuck at everest.hunter.cuny.edu
Sun Apr 13 09:45:52 EDT 1997
Dear Alejandro,
> Has someone succesfully ported GRASS to a Silicon Graphics
> ORIGIN 2000 and if so, what are the switches for the compiler
> to include in the head file.
> Our ORIGIN 2000 has 10 RS10,000 processors, 1.25GBytes of RAM and
> runs IRIX 6.4 OS
> I suppose the first step is to port it for one processor and then try
> with multi-threads. I want to port the modules that take a lot of time to run
> on workstations like r.watershed, r.surf.contour, s.surf.idw,
> s.surf.tps.
Being the original designer/author of r.watershed and r.surf.contour
algorithms (with experience helping someone multi-thread my code), I can
safely say that r.surf.contour can be made faster using multiple
processors. Unfortunately, r.watershed's A* algorithm doesn't
multi-thread well: The time consuming parts must be done one cell at a
time, sequentially.
Based on what I know about s.surf.tps and s.surf.idw, they should be
multi-thread-able.
Good luck, chuck
Charles R. Ehlschlaeger, Assistant Professor
Department of Geography, Hunter College
695 Park Avenue New York, NY 10021
w: 212-772-5321 fax: 212-772-5268
e: chuck at everest.hunter.cuny.edu
http://everest.hunter.cuny.edu/~chuck/
"Come to New York, its not as filthy as you think"
- from Crazy People
