Trimble Pathfinder to GRASS
cameron at ogg.stl.dec.com
Sun Aug 17 23:19:11 EDT 1997
G'day from down under,
Problem Statement
Need hints on what programs in GRASS to use for this task,
and a sequence of operations that would be optimal.
History
I've wandered over a block of land with a Trimble Pro XR DGPS
generating 6327 data points following roads, fences and other
interesting features. The data is accurate to .75m - it was
real-time differential corrected. The data includes elevation.
I've installed GRASS 4.1 on a DIGITAL UNIX system and a DEC
Ultrix system.
Task
Plot the path of a proposed access road so as to minimise cost
of construction and cost of maintenance. The road should be
short enough to be cheap, and yet not so steep as to cause
maintenance problems after the five yearly heavy-rainfall event.
I am buying the block of land to live on, moving out in two
years, and I'd like to take a first cut at this path before
I involve road contracting surveyors.
Problem
How do I get the data into GRASS? I've finally managed to get
point data in as sites by using s.menu to import it in ASCII
format from Trimble's Pathfinder software.
The Trimble software has also generated for line and area
features what it calls ASCII exports for GRASS, but I'm at a
loss for how to import them.
I can create maps in my mapset, but how do I make them
permanent?
Looking forward to any replies. I've been listening on these two
distribution lists for about a week now.
I'm a software engineer, so I can understand most things as long as I
have the words defined. I like bicycles too. ;-) [ref grassp joke]
James Cameron (cameron at stl.dec.com)
Digital Equipment Corporation (Australia) Pty. Ltd. A.C.N. 000 446 800
