Trimble Pathfinder to GRASS
Shawn Francis aem at yknet.yk.ca
Tue Aug 19 21:49:10 EDT 1997
James:
>Problem
>        How do I get the data into GRASS?  I've finally managed to get
>        point data in as sites by using s.menu to import it in ASCII
>        format from Trimble's Pathfinder software.
>        The Trimble software has also generated for line and area
>        features what it calls ASCII exports for GRASS, but I'm at a
>        loss for how to import them.
>        I can create maps in my mapset, but how do I make them
>        permanent?
        We also use a Trimble GPS in our work, except lately we have been
using it to identify porcupine feeding damage locations!  A slight different
from your application.  The Pathfinder Pro Software will directly export an
ascii vector file in GRASS format.  In GRASS, just simple use the v.in.ascii
command and you are away.  It is that easy.  Happy plotting.
Shawn Francis, M.Sc.
Forest Ecologist
Applied Ecosystem Management
100-114 Galena Road
Whitehorse, Yukon  Y1A 2W6
tel/fax (403) 393-3793
aem at yknet.yk.ca
