Continuing problems with importing SDTS files into GRASS
    Henry Shin
    shin_hw at clark.net
    Sun Feb  2 13:00:00 EST 1997
Hello,
I have made some progress in converting SDTS point data file into GRASS.
However, there are number of problems that I am struggling with and I
would very much appreciate some help from those that are familiar with
SDTS conversion.
The SDTS data file that I would like to import has the following
metadata.
Planar:
	Map_Projection:
		Map_Projection_Name: Albers Conical Equal Area
		Alber_Conical_Equal_Area:
			Standard_Parallel: 29.5
			Standard_Parallel: 45.5
			Longitude_of_Central_Meridan: -96
			Latitude_of_Projection_Origin: 23
			False_Easting: 0.0
			False_Northing: 0.0
When I followed the menu options for creating a new location, I got the
following error: (I used the "Other" option then selected Albers Conical
Equal Area Prjection)
Processing CATD module
Processing STAT module
Processing IDEN module
Processing XREF module
Warning: Current GRASS projection (Other) does not match SDTS data set
projection (Latitude-Longitude)
Entering 'Information Only' mode
Processing IREF module
         INFORMATION ABOUT THE SDTS DATA SET
Identification module:  PREFIDEN.DDF
Standard identification:           SPATIAL DATA TRANSFER STANDARD
Standard version:                  1992 AUGUST 28
Standard documentation reference:  FIPS PUB 173 - 1992
Profile identification:            SDTS TOPOLOGICAL VECTOR PROFILE
Profile version:                   VERSION 1.0 JUNE 10, 1994
Profile documentation reference:   FIPS 173-1 PART 4
Title:                             BOX_COV,LANDFILL:
Data ID:
Data structure:                    ARC/INFO
Map date:
Data set creation date:            19961122
Scale:
Comment:
External Spatial Reference module:  PREFXREF.DDF
Reference System name:                  GEO
Horizontal Datum:                       NONE
Zone Number:                            0
Spatial Domain module:  PREFSPDM.DDF
Spatial Domain type:                    MINMAX
MAP:    box_cov
THEME:  *
MANIFOLD:       box_cov
BOUNDARY:
        MIN_X   MIN_Y   MAX_X   MAX_Y
        -124.106422  25.935798  -66.993011  48.986392
Done.
According to the error message, it looks like I should have selected
Long-Lat map projection instead of "Albers Conical Equal ARea". So, I
creasted a new location with Long-Lat projection and proceeded to
convert the data. Unfortunately, v.in.sdts exited with segmentation
fault.
Processing manifold: box_cov
Processing LE module: PREFLE01.DDF
Processing PC module: PREFPC01.DDF WARNING: No area_point for attributed
area 'PC01#2' found
Processing NO Module: PREFNO01.DDF
Processing NE Module: PREFNE01.DDF . . . . . . . . . . . . . . . . . . .
Processing GRASS dig_atts
Schema Type = '1'
Processing attribute modules . . .
Writing Composite Attribute modules
Writing Attribute Primary modules (6)
  PREFAXRF.DDF
  PREFAPNE.DDF Segmentation fault (core dumped)
Well, I am stucked! I would appreciate any help resolving this problem.
Thank you for reading this long post.
Henry Shin
