importing BIL files that are not on tape
Malcolm Williamson
malcolm at cast.uark.edu
Tue Feb 4 12:51:57 EST 1997
On Tue, 4 Feb 1997, Philip Verhagen wrote:
> Dear all,
> I was hoping someone could help me out on the following: I have transferred
> BIL files from CDROM to my machine and tried reading them into Grass using
> i.tape.other - however, the program is refusing to import the files and
> produces a core dump when I specify the BIL file as the 'tape' to be read.
> Is there some quick and dirty solution to this?
> Philip Verhagen
Hi, Philip
I have successfully used i.tape.other this way before with no problems. I
assume that your BIL file is multi-band; if not, you can directly copy
the file to the GRASS cell directory and use r.support to build the other
needed files. I'm afraid that I don't know what could be causing the core
dump. Have you successfully run the i.tape.other command before?
-Malcolm
Malcolm D. Williamson - GIS Specialist E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-6159
Ozark Rm. 12 Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
