sol 2.5.1 colormap allocation errors
Angus Carr
apcarr at FLASH.LakeheadU.CA
Thu Feb 6 17:43:25 EST 1997
This problem shows you are using a 24 bit colour map.
Switch the Xserver (openwindows) to an 8-bit mode and it will work in all
of the below cases.
X uses a colour map only in 256 colour map, and GRASS demands a colour
map. XDRIVER24 is a hack to use a 24bit display. It's a working hack,
however.
Angus Carr.
On Thu, 6 Feb 1997 gomlra3!ohler at atlas.il.nrcs.usda.gov wrote:
> Hello Grass users --
> I am running GRASS 4.1 update 5 on a sparc 5 with Solaris
> 2.5.1. After compiling and recompiling the XDRIVER I
> still get the following error when executing d.mon:
> X Error of failed request: BadMatch (invalid parameter attribute)
> Major Opcode of failed request: 78 (X_CreateColorMap)
> Serial Number of failed request: 229
> Current serial number in output stream: 230
> Poking around on the moon.ftp site I found a different XDRIVER
> called XDRIVER24. I went ahead and compiled that one, and I
> am able to use it for the display device. However, this driver
> does not allow floating point colormode.
> As an additional indicator there is something off on the machine,
> two related software packages have the same problem:
> - When trying to start LT Plus (compiled on site),
> I get an identical error to the one above.
> - When starting Grasslands (obtained from ftp site),
> an information box indicates the inability to create
> the colormap, then exits.
> I would like to know if anyone has seen this before,
> and could suggest a remedy.
> I appreciate your help...
> Eric Ohler
> USDA - NRCS
