Digitizer
Venkatesh Raghavan
raghavan at media.osaka-cu.ac.jp
Fri Feb 28 02:11:44 EST 1997
Hello,
I am using GRASS4.1.5 on LINUX. My digitizer emulates Calcomp 9100
and I am trying to use it with v.digit. The digitizer seems to
be working okay when I run the calc_diag program. I can also
use my digitizer under MS-DOS. However, when I run it with
v.digit, I select my digitizer and vector file and the screen
prompt "Do you want to continue [y/n] ? " appears. when I answer
yes I get a segmentation fault. Can anybody give me some suggestions
to get my digitizer working.
Thanks in advance
ベンカテッシュ ラガワン Venkatesh Raghavan
大阪市立大学学術情報総合センター Media Center, Osaka City Univ.
3ー3ー138杉本住吉区大阪 558 3-3-138 Sugimoto Sumiyoshi-ku, Osaka
558
Tel:06-605-3381
mailto:raghavan at media.osaka-cu.ac.jp
