Sharon Mesick x7665
    mesick at dolphins.ssc.nasa.gov
    Mon Jun  2 13:17:45 EDT 1997
Nicola Fohrer wrote:
> Dear Grass Users,
> importing Ascii-File to Erdas Gis - exporting as Grass -File
> I have created a map (DEM) in Erdas by reading an ASCII-File. The
> data type is Float Single and the projection is Transverse Mercator.
> Exporting this map as a Grass-file, Erdas gives the warning that
> float data can only be exported as integer.
> If I accept and create a location and mapset it can only be imported
> into Grass without any projection (plane) although it is exported as
> 1. Is Grass not able to manage float data maps ?
> 2. How can I save the projection TM during the transfer from Erdas to
>     Grass ?
> Stephan
> Dr. sc. agr. Nicola Fohrer
> Wissenschaftliche Assistentin
> Institut fuer Landeskultur
> Senckenbergstr. 3
> 35 390 Giessen
> Tel:0641/99 37385
> Fax:0641/99 37389
> email:Nicola.Fohrer at agrar.uni-giessen.de
My experience with GRASS is somewhat limited, but I can tell you for
certain that a GRASS raster file can only be an integer type.  For my
data sets, where the float value is very important, I pre-process the
ASCII data by mulitplying such that the floating point becomes an
integer which contains all necessary values.  For example, 25.9 bcomes
259 - I also have to adjust my standardized color scale (in the colr
directory) and my category file to accomodate this change.  Hope this
info will be useful to you.
Sharon Mesick
