r.mapcalc loops
R.A.Sanderson R.A.Sanderson at newcastle.ac.uk
Fri Jun 27 05:21:40 EDT 1997
Dear Erin
Try this in your shell script:
At 19:10 26/06/97 +0000, you wrote:
>Is it possible to do a loop within r.mapcalc?  If so, could someone
>post an example of how I could increment the i and j variables that
>indicate the relative position of a pixel (eg., x[-1,2].  I
>determined that I could put an address in those positions and do the
>loop around r.mapcalc, but I assume I could save time if I can do it
>within.  I want to do a pretty big neighborhood but keep the window
>resolution high.  If I were a REAL woman of course I would do it all
>in C, but it boggles my mind.  Any suggestions?  I'm trying to
>put an error distribution around telemetry points.
>My guts of my current script is like this:
>r.mapcalc count_sites = 0
while [ $i != 5 ]
do
   j=1
   while [ $j != 5 ]
   do
       put in whatever weights you're using
       r.mapcalc count_sites = count_sites + telempts[i, j]
       j=`expr $j + 1`
       done
   i=`expr $i + 1`
done
Hope I've understood your question properly and this helps to answer it!
Regards
Roy
Roy Sanderson
Centre for Land Use and Water Resources Research
Porter Building
University of Newcastle
Newcastle upon Tyne
NE1 7RU
United Kingdom
Tel: +44 191 222 7789
Fax: +44 191 222 6563
URL: http://www.cluwrr.ncl.ac.uk
