GRASS data
Malcolm Williamson
malcolm at cast.uark.edu
Mon Mar 31 14:27:16 EST 1997
On Mon, 31 Mar 1997, Zhihui Wan wrote:
> Hi,
> Would anyone know if GRASS is able to convert other commonly-seen GIS
> data format to GRASS format?
> Thanks a lot.
> Zhihui Wan :-)
> System & Network Administrator, Intersoft Systems Ltd.
> #555 333 11th Ave. SW, Calgary, AB T2R 1L9
> Email: zhw at travelsurf.com ; Fax: (403) 233-7266
> Phone: office (403) 543-0078
I think you'll find the accompanying summary useful.
-Malcolm Williamson
>From grass-lists-owner at max.cecer.army.mil Mon Nov 15 14:16:27 1993
Return-Path: <grass-lists-owner at max.cecer.army.mil>
Received: from max.cecer.army.mil by goby.uark.edu.cast (4.1/SMI-4.1)
id AA18649; Mon, 15 Nov 93 14:16:27 CST
Received: from amber.cecer.army.mil by max.cecer.army.mil with SMTP id AA18391
(5.67a/IDA-1.5 for <malcolm at goby.uark.edu>); Mon, 15 Nov 1993 14:05:57 -0600
Received: from max.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1)
id AA00648; Mon, 15 Nov 93 14:02:26 CST
Received: from zorro.cecer.army.mil by max.cecer.army.mil with SMTP id AA18354
(5.67a/IDA-1.5 for <grassu-people at max.cecer.army.mil>); Mon, 15 Nov 1993 14:02:26 -0600
Received: from amber.cecer.army.mil by zorro.cecer.army.mil with SMTP id AA14071
(5.67a/IDA-1.4.4 for <grassu-people>); Mon, 15 Nov 1993 14:02:24 -0600
id AA00642; Mon, 15 Nov 93 14:02:20 CST
Received: from zorro.cecer.army.mil by max.cecer.army.mil with SMTP id AA18350
(5.67a/IDA-1.5 for <grassu-list at max.cecer.army.mil>); Mon, 15 Nov 1993 14:02:21 -0600
Received: by zorro.cecer.army.mil id AA14066
(5.67a/IDA-1.4.4 for grassu-list at max.cecer.army.mil); Mon, 15 Nov 1993 14:02:18 -0600
Date: Mon, 15 Nov 1993 14:02:18 -0600
Message-Id: <199311152002.AA14066 at zorro.cecer.army.mil>
Sender: grass-lists-owner at max.cecer.army.mil
Reply-To: grassu-list at max.cecer.army.mil
Precedence: Bulk
Subject: Re: Grass supported data formats
Status: RO
X-Status:
This was discussed on the user's list about a month ago. Here's the
summary I found:
Carl_Dichter at email.mot.com (Carl Dichter)
Re: GRASS Import/Export Formats (Summary)
7 Oct 93 16:40:39 GMT Motorola GSTG Positioning Systems CBU
Newsgroups: info.grass.user
References: <1993Oct6.221014.28089 at schbbs.mot.com>
Two people provided answers to my question "What file formats
(DXF, DLG, DIME, TIGER, IGDF, etc) can GRASS read and write?"
Thanks for your help.
Here are their answers:
In article 9310071225.AA13768 at pasture.ecn.purdue.edu, mccauley at ecn.purdue.edu (Darrell McCauley) says:
>I'm not a great importer/exporter of maps, but
>a quick check of [r|s|v].[in|out].* reveals:
>r.in.ascii r.in.ll r.in.poly r.in.sunrast r.in.utm r.out.ascii
>r.out.tga v.in.arc v.in.dlg v.in.dxf v.in.tig.basic v.in.tig.rim
>v.in.ascii v.in.dlg.scs v.in.poly v.in.tig.lndmk v.in.transects
>v.out.arc v.out.ascii v.out.dlg v.out.dxf v.out.moss s.in.ascii
>s.out.ascii
>So, for input, it appears to support ascii, arc, dxf, tiger,
>dlg, and sunrast (with pbmplus -> any common image format).
>For output, it appears to support ascii, targa, arc, dlg, dxf,
>and moss.
>Disclaimer: I've never used very many of these.
>--Darrell
>From markline(a)henson.cc.wwu.edu:
>At *least* the following (there's contributed software out there that I
>probably don't know about; what's listed here seems to actually work: 8)
>Imagery Import:
> erdas
> MSS tape
> SPOT tape
> TM tape
> generic tape
>Raster Import:
> ASCII
> SUN screendump
> USGS DEM tape
> DMA DTED on USGS tape
> DMA DTED tape
> USGS Landuse/Landcover Composite Theme Grid (LULC CTG)
>Vector Import:
> ARC
> ASCII (Coordinates)
> ASCII (Transects)
> DLG
> DLG2
> DXF
> TIGER
>Point Import:
> ASCII
> U.S. Census PL94-171 dBase3 CD-ROM
> U.S. Census STF1A dBase3 CD-ROM
>Raster Export:
> ASCII
>Vector Export:
> ARC
> ASCII
> DLG
> DXF
> MOSS
>Point Export:
> ASCII
>Also, you can generally convert among GRASS' own formats and between UTM
>and Lat-Long.
>I'll keep my eyes open for other readers/writers that I might come across.
>Hope this helps.
>-- Mark
>Mark P. Line Phone: +1-206-733-6040
>Open Pathways Fax: +1-206-733-6040
>P.O. Box F Email: markline at henson.cc.wwu.edu
>Bellingham, WA 98227-0296
