DXF Shift in State Plane
Bruce Nielsen bnielsen at in.nrcs.usda.gov
Thu May 1 08:54:39 EDT 1997
Kathy Burroughs wrote:
> Hi Grassusers:
> A short question.  Has anyone worked with GRASS and the State Plane
> System.  We are trying to import dxf files that were created with
> State Plane.  When overlaying the data on orthos or other existing data
> the dxf has shifted several thousand feet to the East.  The north/south
> orientation is correct.  Is there a problem with v.import and State Plane?
> Any suggestions?
> Thanks in Advance.
> Kathy Burroughs
> GIS Spec - NRCS, Athens, GA
> kathy at nrcsga.ga.nrcs.usda.gov
Kathy,
If the East-West shift is consistant throughout the map, you might try
v.transform to move the map to the right coordinates.
Bruce Nielsen                bruce.nielsen at in.nrcs.usda.gov
GIS Specialist
USDA-Natural Resources Conservation Service
6013 Lakeside Blvd.          VOICE (317) 290-3200 ext. 349
Indianapolis, IN 46278       FAX   (317) 290-3225
