your mail
Malcolm Williamson malcolm at cast.uark.edu
Thu May 1 10:40:21 EDT 1997
Hi, Kathy
Do these dxf files come from a highway department? If so, (and possibly
even if not) they may not be drawn to a "standard" State Plane coordinate
system. The originator should be quizzed for details on the coordinate
system, and then you can compare these to the GRASS definition. You may
have to make a new Location, and then use v.proj to reproject the
vectors.
Malcolm D. Williamson - GIS Specialist           E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-6159
Ozark Rm. 12                                        Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
 On Wed, 30 Apr 1997, Kathy Burroughs wrote:
> Hi Grassusers:
> A short question.  Has anyone worked with GRASS and the State Plane
> System.  We are trying to import dxf files that were created with
> State Plane.  When overlaying the data on orthos or other existing data
> the dxf has shifted several thousand feet to the East.  The north/south
> orientation is correct.  Is there a problem with v.import and State Plane?
> Any suggestions?
> Thanks in Advance.
> Kathy Burroughs
> GIS Spec - NRCS, Athens, GA
> kathy at nrcsga.ga.nrcs.usda.gov
