importing dxf-files
jan.bogaert jbo at bogy.uia.ac.be
Tue May 13 09:22:17 EDT 1997
Hello GRASS-users,
I hope someone can help me.
I'm trying to import a dxf-file (name=kaart), containing 12 different
groups of polygons, i.e. 12 different labels are present on the map (pine
forest, deciduous forest, ...).
Using "v.in.dxf", 12 files (kaart.1, kaart.2, kaart.3, ..., kaart.12) are
made and stored in the directory "/dig", as explained in the manual. So
the 12 different classes are recognized.
However, the next step is not going on, i.e. the step of using
"v.cadlabel". The message is that I first have to run "v.support" on the
files, but, after that, I get the message that for every polygon no text
label is attached to it ("Textfile line ... NOT labelled").
Furthermore, using "v.info" it is clear that no information is present in
the file/map.
Has someone experience with importing dxf-files from other GIS ??
Many thanks in advance.
P.S. The files are generated by the GIS GENAMAP.
-jan
  ir. lic. Jan Bogaert
  Universitaire Instelling Antwerpen - Departement Biologie
  Laboratorium voor Plantecologie - Universiteitsplein 1
  B-2610 Antwerpen (Wilrijk) - Belgium
  fax. +32 3 820 22 71 - tel. +32 3 820 22 82
  E-mail jbogaert at uia.ua.ac.be - jbo at bogy.uia.ac.be
