m.dem.extract error?
H. Thomas Foster, II
htf1 at psu.edu
Fri May 30 14:01:51 EDT 1997
I am trying to extract a dem. I assume i should be using m.dem.extract.
m.dem.examine will recognize it as will m.dem.extract. However, when I give
it all the necessary info it exits with the folowing error:
ERROR: could not find data in correct file.
what am i doing wrong? the Reference Manual says somthing about getting a
similar error if the C record is 0 and indeed m.dem.extract says that C
record: 0. the manual says that the format could be wrong and to fast
forward to the next file on the tape. I am not extracting from a tape so I
don't know what to do. Does this mean that I can't extract this dem?
thanks for any information
Thomas Foster email: htf1 at psu.edu
Pennsylvania State University voice: 814-865-1231
Department of Anthropology fax: 814-863-1474
409 Carpenter Bldg.
University Park, PA 16802
