mapgen how to!
    Stephan Eickschen
    eicksch at uni-muenster.de
    Sat Nov  1 19:10:50 EST 1997
Jill,
thanks for your help, but I have still some problems. I have copied the
script mapgen4.1 to $GIS/scripts. I started GRASS, entered my MAPSET,
started mapgen4.1, was prompted if I want [e]xisting, (n)ew ..., entered
"n", entered the name of the desired map ("Topographie") and got:
>   Welcome to the SCS-GRASS/MAPGEN Interface version 4.13
>         Default options are enclosed in brackets [].
>         To accept the default type the return.
>   You are editing map Topographie
>   Your current directory is
> /scratch/eicksch/grass-data/Ekstroemisen/Synoptic/mapgen/Topographie
>         When ready to quit, type exit.
> earth:/scratch/eicksch/grass-data/Ekstroemisen/Synoptic/mapgen/Topographie >
I couldn´t start _any_ of the scripts in $GIS/mapgen/interface, because
for
some reason - which I don´t understand - the PATH variable didn´t
change. All
the other setup succeded, as you might see from my excerpt from using
env
right at the mapgen-prompt (s. attachment).
Do you have any suggestions?
Regards,
	Stephan
P.S.:
> PATH=/usr/ucb:/bin:.:$GRAPH/bin:$GRAPH/interface:$PATH
	This path doesn´t exist on our machine; is it necessary?
_=/exports/sgi/GRASS/grass4.1/etc/run
TCL_LIBRARY=/usr/local/lib/tcl
LANG=C
PLZDIR=/usr/local/lib/plz
PSPAINTER=printer-a4
HZ=100
GISDBASE=/scratch/eicksch/grass-data/
ERLFONTS=/usr/local/lib/FONTDAT
ENSCRIPT=-2rG -p list.ps
EXPLORERHOME=/usr/explorer
LOCATION_NAME=Ekstroemisen
PATH=.:/home/eicksch/:/usr/freeware/bin:/usr/bin:/home/eicksch/bin:/usr/sbin:/usr/gnu/bin:/usr/bsd:/usr/local/bin:/usr/dyn/local/bin:/usr/sbin:/usr/local/gmt/bin:/bin:/usr/bin:/usr/bin/X11:/usr/explorer/bin:/home/eicksch/utils:/etc:/usr/etc:/usr/demos/bin:/usr/local/pbm/bin:/home/eicksch/moviebin:/usr/local/lam/bin:/exports/sgi/gmt:/home/grass
GISBASE=/exports/sgi/GRASS/grass4.1
GRAPHB=/exports/sgi/GRASS/grass4.1/mapgen/bin/plotter:/exports/sgi/GRASS/grass4.1/mapgen/gfonts/:sr:
NOMSGLABEL=1
REMOTEUSER=eicksch
NNTPSERVER=news.cc.ruu.nl
TK_LIBRARY=/usr/local/lib/tk
CFDEXPLORERHOME=/usr/dyn/schmalzl/explorer/cfd
XUSERFILESEARCHPATH=/usr/dyn/schmalzl/.desktop-dynamo/%N:/usr/dyn/schmalzl/dat/config/sgi-color1280/%N:/usr/dyn/schmalzl/.app-defaults/%N:/usr/lib/X11/app-defaults/sgi-color1024/%N:/usr/lib/X11/app-defaults/color1024/%N:/usr/dyn/schmalzl/.Xdefaults
MNAME=Topographie
OPENWINHOME=/usr/dyn/schmalzl/dat/xview3
GRAPH=/exports/sgi/GRASS/grass4.1/mapgen
MAPSET=Synoptic
LOCATION=/scratch/eicksch/grass-data//Ekstroemisen/Synoptic
LOGNAME=eicksch
LS_COLORS=di=5;45:*.c=34;47:*.f=35;37:*.F=35;46:ex=33;1:*.h=32;41:ln=36;1
MAIL=/usr/mail/eicksch
PS1=
 Mapset <Synoptic> in Location <Ekstroemisen> in MAP <Topographie>
 GRASS-MAPGEN 4.13 >
PRINTER=lpeicksch
HOST=earth
GISRC=/home/eicksch/.grassrc
USER=eicksch
SHLVL=3
LD_LIBRARY64_PATH=/usr/local/lib
MSGVERB=text:action
NENSCRIPT=-2rG -p list.ps
DISPLAY=KIWI.UNI-MUENSTER.DE:0
SHELL=/bin/tcsh
HOSTTYPE=iris4d
MESA_LIB=/geodyn/schmalzl/Mesa/lib
PVM_ROOT=/geodyn/schmalzl/pvm3
GS_LIB=/usr/local/lib/gs
REMOTEHOST=KIWI.UNI-MUENSTER.DE
XPVM_ROOT=/geodyn/schmalzl/pvm3/xpvm
HOME=/home/eicksch
VDEVICE=X11
HFONTLIB=/usr/local/lib/hershey
TERM=xterm
PROJ_LIB=/exports/sgi/GRASS/grass4.1/etc
WINTERM=xwsh -fg black -bg white -cursorbg black -boldfont 9x15bold -bold black -cursorfg black -selbg black -selfg white -fn 9x15bold
GIS_LOCK=18908
PWD=/scratch/eicksch/grass-data/Ekstroemisen/Synoptic/mapgen/Topographie
EXPLORERUSERHOME=/usr/dyn/schmalzl/explorer
TZ=PST8PDT
CXMODULES_INST=/usr/dyn/schmalzl/explorer
NOMSGSEVERITY=1
LOCAL_LDFLAGS=/lib:/usr/lib:/usr/local/lib
LLIB=/usr/local/lib
