mapgen how to!
Jill Schuler
jschuler at tulip.itc.nrcs.usda.gov
Tue Nov 4 11:06:19 EST 1997
Stephan,
It looks like you dont even have the GRASS directories added to your path.
When I start GRASS I get the following added to my path:
/4.13_bin/bin:/4.13_bin/scripts:/4.13_bin/garden/bin:/4.13_bin/tools:
then when I start MAPGEN I get the following added to my path:
/usr/ucb:/bin:.:/4.13_bin/mapgen/bin:/4.13_bin/mapgen/interface:
the /usr/ucb is a solaris2.x thing for the echo command. You can take this
out. The scripts are written using the echo that understands "-n" syntax.
Do you have bourne shell support???? If you dont have bourne support the
easiest way to fix this is to hardcode the software paths in your system setup
files (.chsrc or .login or .profile). Be sure to add the GRASS paths as
well as the MAPGEN paths.
Additionally, make sure you have the command gzip and gzcat linked to the
GISBASE/tools directory. MAPGEN uses these tools in the dig.to.geo and
make.line commands.
Jill
----- Begin Included Message -----
I couldn´t start _any_ of the scripts in $GIS/mapgen/interface, because
for
some reason - which I don´t understand - the PATH variable didn´t
change. All
the other setup succeded, as you might see from my excerpt from using
env
right at the mapgen-prompt (s. attachment).
> PATH=/usr/ucb:/bin:.:$GRAPH/bin:$GRAPH/interface:$PATH
This path doesn´t exist on our machine; is it necessary?
--------------167E2781446B
Content-Type: text/plain; charset=us-ascii; name="env.txt"
Content-Transfer-Encoding: 7bit
Content-Disposition: inline; filename="env.txt"
_=/exports/sgi/GRASS/grass4.1/etc/run
TCL_LIBRARY=/usr/local/lib/tcl
LANG=C
PLZDIR=/usr/local/lib/plz
PSPAINTER=printer-a4
HZ=100
GISDBASE=/scratch/eicksch/grass-data/
ERLFONTS=/usr/local/lib/FONTDAT
ENSCRIPT=-2rG -p list.ps
EXPLORERHOME=/usr/explorer
LOCATION_NAME=Ekstroemisen
PATH=.:/home/eicksch/:/usr/freeware/bin:/usr/bin:/home/eicksch/bin:/usr/sbin:/usr/gnu/bin:/usr/bsd:/usr/local/bin:/usr/dyn/local/bin:/usr/sbin:/usr/local/gmt/bin:/bin:/usr/bin:/usr/bin/X11:/usr/explorer/bin:/home/eicksch/utils:/etc:/usr/etc:/usr/demos/bin:/usr/local/pbm/bin:/home/eicksch/moviebin:/usr/local/lam/bin:/exports/sgi/gmt:/home/grass
GISBASE=/exports/sgi/GRASS/grass4.1
GRAPHB=/exports/sgi/GRASS/grass4.1/mapgen/bin/plotter:/exports/sgi/GRASS/grass4.1/mapgen/gfonts/:sr:
NOMSGLABEL=1
REMOTEUSER=eicksch
NNTPSERVER=news.cc.ruu.nl
TK_LIBRARY=/usr/local/lib/tk
CFDEXPLORERHOME=/usr/dyn/schmalzl/explorer/cfd
XUSERFILESEARCHPATH=/usr/dyn/schmalzl/.desktop-dynamo/%N:/usr/dyn/schmalzl/dat/config/sgi-color1280/%N:/usr/dyn/schmalzl/.app-defaults/%N:/usr/lib/X11/app-defaults/sgi-color1024/%N:/usr/lib/X11/app-defaults/color1024/%N:/usr/dyn/schmalzl/.Xdefaults
MNAME=Topographie
OPENWINHOME=/usr/dyn/schmalzl/dat/xview3
GRAPH=/exports/sgi/GRASS/grass4.1/mapgen
MAPSET=Synoptic
LOCATION=/scratch/eicksch/grass-data//Ekstroemisen/Synoptic
LOGNAME=eicksch
LS_COLORS=di=5;45:*.c=34;47:*.f=35;37:*.F=35;46:ex=33;1:*.h=32;41:ln=36;1
MAIL=/usr/mail/eicksch
PS1=
Mapset <Synoptic> in Location <Ekstroemisen> in MAP <Topographie>
GRASS-MAPGEN 4.13 >
PRINTER=lpeicksch
HOST=earth
GISRC=/home/eicksch/.grassrc
USER=eicksch
SHLVL=3
LD_LIBRARY64_PATH=/usr/local/lib
MSGVERB=text:action
NENSCRIPT=-2rG -p list.ps
DISPLAY=KIWI.UNI-MUENSTER.DE:0
SHELL=/bin/tcsh
HOSTTYPE=iris4d
MESA_LIB=/geodyn/schmalzl/Mesa/lib
PVM_ROOT=/geodyn/schmalzl/pvm3
GS_LIB=/usr/local/lib/gs
REMOTEHOST=KIWI.UNI-MUENSTER.DE
XPVM_ROOT=/geodyn/schmalzl/pvm3/xpvm
HOME=/home/eicksch
VDEVICE=X11
HFONTLIB=/usr/local/lib/hershey
TERM=xterm
PROJ_LIB=/exports/sgi/GRASS/grass4.1/etc
WINTERM=xwsh -fg black -bg white -cursorbg black -boldfont 9x15bold -bold black -cursorfg black -selbg black -selfg white -fn 9x15bold
GIS_LOCK=18908
PWD=/scratch/eicksch/grass-data/Ekstroemisen/Synoptic/mapgen/Topographie
EXPLORERUSERHOME=/usr/dyn/schmalzl/explorer
TZ=PST8PDT
CXMODULES_INST=/usr/dyn/schmalzl/explorer
NOMSGSEVERITY=1
LOCAL_LDFLAGS=/lib:/usr/lib:/usr/local/lib
LLIB=/usr/local/lib
--------------167E2781446B--
----- End Included Message -----
