[Q] About v.in.dxf
Angus Carr
apcarr at FLASH.LakeheadU.CA
Thu Nov 20 03:18:42 EST 1997
There is a copy of v.in.dxf3d in the grass4.2 source code.
If you can't get, it, drop me a line at apcarr at flash.lakeheadu.ca and
I'll post it to you.
Angus Carr
> Hello, Choi,
> If I do understand your mail you have a dxf file with some information
> like topographic contours, rivers & streams and things alike.
> I got a similar problem to import elevation information from dxf files
> because I had several digitised maps in Autocad R12 vector format that I
> exported to dxf to interchange information (as the name itself means...)
> With v.in.dxf I've only obtained the polylines and points of my original
> file with *no* elevation data attached - and this was not exactly what I
> wanted to generate a DEM.
> I found two solutions but I wish not as good as one may want.
> First: I tested a demo version of Grassland (its timelife span is a
> mere 30 days period) and its v.in.dxf3d works fine. But you must pay for
> this and, the worst, it runs under Win95...
> Second: I made a dirty & snail-pacer Matlab routine that reads the
> ascii dxf file and extracts a site list (easting, northing, elevation)
> of all polyline vertexes and points I got digtised. It's not an elegant
> solution but it works if you need only this site list.
> If this Matlab routine can make any job for you, I can mail it for you.
> But I think this can be better: do you have better programming skills
> than me in order we can write a tiny utility to do this job?
> Is there anybody here who can help? I'm not a programmer but it does
> not seem to be a very, very difficult task. At least, as starting point
> I made that simple Matlab routine and I think the dxf file format is not
> so difficult to read (to say the truth, it's quite verbose and explicit
> for one who wants to collect data from it).
> Best regards,
> Adalberto da Silva
> Instituto Astronomico e Geofisico
> Universidade de Sao Paulo - Brasil
> adalbert at iag.usp.br
> Sung-Won Choi wrote:
> > Hi!
> > I have a dxf map in AutoCad...
> > And I'd like to import this map to Grass 4.1
> > But I don't know.
> > I need a vector file and a attribute file of that.
> > When I used a v.in.dxf, Vector file was imported but Attribute file wasn't.
> > Please Help me!
> > Thank you.
