Problems linking XGRASS
    Stephan Eickschen
    eicksch at uni-muenster.de
    Mon Sep 15 11:21:39 EDT 1997
Hello all,
after having solved the last problem (Thanks to Justin Hickey :-) )
I thought, that everything should work, BUT:
> ld32: ERROR 33: Unresolved text symbol "MAX" -- 1st referenced by >/exports/sgi/GRASS/grass4.1/src/xgrass/libes/LIB.irix/libXgi.a(Help.o).
Up to now, I know, that MAX(...) is defined in color.c. How can I tell
the rest of the sources to use the definition????
I think, that the solution will be as simple as for my first question,
but.... So, please forgive me.
Cheers,
	Stephan
Stephan Eickschen                     Tel. : +49 (0)251 83-34704
Westfaelische Wilhelms-Universitaet   Fax. : +49 (0)251 83-36100
Institute for Geophysics
Research Unit of Physical Glaciology  email: eicksch at uni-muenster.de
Corrensstrasse 24
48149 Muenster
Germany
