grass421_on_linux:compilation errors.
Andrew M McDermott mcdermam at potsdam.edu
Tue Dec 15 12:28:34 EST 1998
At 10:47 AM 12/15/98 +0100, you wrote:
>Hi!
>I've compiled most of the programs on a
>Linux (RedHat 5.1) box, but got some problems with
>1. g77 (see below)
>Should not gcc take care of F77 ?
>It seems that I do not have a g77 compiler, is it not
>standard with the Linux distribution?
>2. and then another one with run.setup
>/usr/local/grass42/src421/src.related/rim
>  mkdir OBJ.linux
>  make -f OBJ.linux/make.rules
>run.setup
>make: run.setup: Command not found
>make: *** [rim] Error 127
>GISGEN failure at STEP: src.related/rim
>Any help?
>Thanks
>Dr. Agustin Lobo
>Instituto de Ciencias de la Tierra (CSIC)
>Lluis Sole Sabaris s/n
>08028 Barcelona SPAIN
>tel 34 93409 5410
>fax 34 93411 0012
>alobo at ija.csic.es
>http://pangea.ija.csic.es/alobo
>/usr/local/grass42/src421/src.contrib/CERL/misc/m.eigensystem
>  mkdir OBJ.linux
>rm -f OBJ.linux/main.o
>g77  -c main.f
>make: g77: Command not found
>make: *** [OBJ.linux/main.o] Error 127
>GISGEN failure at STEP: src.contrib/CERL/misc/m.eigensystem
>[root at localhost CMD]# pwd
>/usr/local/grass42/src421/src/CMD
>/usr/local/grass42/src421/src.garden/answers/src.answers/answers
>  mkdir OBJ.linux
>make[1]: Entering directory
>`/usr/local/grass42/src421/src.garden/answers/src.answers/answers'
>rm -f OBJ.linux/answers.o
>g77  -c answers.f
>make[1]: g77: Command not found
>make[1]: *** [OBJ.linux/answers.o] Error 127
>make[1]: Leaving directory
>make: *** [all] Error 1
>GISGEN failure at STEP: src.garden/answers/src.answers
>/usr/local/grass42/src421/src.garden/answers/raster/r.direct/cmd
>  mkdir OBJ.linux
>`/usr/local/grass42/src421/src.garden/answers/raster/r.direct/cmd'
>rm -f OBJ.linux/direct.o
>gcc -O2 -m486 -DATT_386  -I/usr/local/grass42/src421/src/include
>-DUSE_TERMIO -c direct.c
>direct.c: In function `main':
>direct.c:77: warning: passing arg 1 of `strcpy' from incompatible pointer
>type
>direct.c:78: warning: passing arg 1 of `strcpy' from incompatible pointer
>type
>mv direct.o OBJ.linux/direct.o
>rm -f OBJ.linux/cell_open.o
>-DUSE_TERMIO -c cell_open.c
>mv cell_open.o OBJ.linux/cell_open.o
>rm -f OBJ.linux/cell_open_new.o
>-DUSE_TERMIO -c cell_open_new.c
>mv cell_open_new.o OBJ.linux/cell_open_new.o
>gcc -Wl,-s OBJ.linux/direct.o OBJ.linux/cell_open.o
>/usr/local/grass42/src421/src/libes/LIB.linux/libgis.a -lm -o
>/usr/local/grass42/etc/bin/alpha/cmd/r.direct
>/usr/local/grass42/src421/src/libes/LIB.linux/libgis.a(gets.o): In
>function `G_gets':
>gets.o(.text+0x60): the `gets' function is dangerous and should not be used.
>rm -f OBJ.linux/direct_for.o
>g77  -c direct_for.f
>make[1]: *** [OBJ.linux/direct_for.o] Error 127
>GISGEN failure at STEP: src.garden/answers/raster/r.direct
>  mkdir OBJ.linux
>run.setup
>/usr/local/grass42/src421/src.garden/grass.rim/s.db.rim/cmd
>  mkdir OBJ.linux
>make[2]: Entering directory
>`/usr/local/grass42/src421/src.garden/grass.rim/s.db.rim/cmd'
>rm -f OBJ.linux/highlevel.o
>-DUSE_TERMIO -c highlevel.c
>mv highlevel.o OBJ.linux/highlevel.o
>cc -Wl,-s -o /usr/local/grass42/etc/bin/main/cmd/s.db.rim
>OBJ.linux/highlevel.o /usr/local/grass42/src421/src/libes/LIB.linux/libgis.a
>/usr/local/grass42/src421/src/libes/LIB.linux/libgis.a(parser.o): In
>function `interactive_option':
>parser.o(.text+0x1331): the `gets' function is dangerous and should not
>be used.
>rm -f OBJ.linux/s.db.rim.o
>g77  -c s.db.rim.f
>make[2]: g77: Command not found
>make[2]: *** [OBJ.linux/s.db.rim.o] Error 127
>make[2]: Leaving directory
>make[1]: *** [all] Error 1
>`/usr/local/grass42/src421/src.garden/grass.rim/s.db.rim'
>GISGEN failure at STEP: src.garden/grass.rim
You might not have a fortran compiler,it might not be in your path, or it
might be in your path but named something else (like f77). The standard
place for it would be /usr/bin or /usr/local/bin.
The distribution you are using might not install with fortran as a standard
option, e.g. in Slackware I have to choose the development tools as an
option in setup.
gcc and g77 are distinct compilers, though g77 musr be compiled into gcc
for compatibility. You might have to get a version of the g77 source code
appropriate to your gcc and then recompile according to the included
installation instructions.
