r.out.bil
Johnny Duke jduke at ar.nrcs.usda.gov
Tue Dec 22 07:58:28 EST 1998
Here is a script that works better for getting Grass raster
files to BILs. This scripts is for black and white.  The other
scripts is for color.
Merry Christmas to all!!
Johnny Duke
GIS TEch.
USDA/NRCS
USA
# This script reads a GRASS cellhd file and creates a "world" file and "header"
# file for display in ArcView or ArcInfo as a "bil" file.
# files are stored under $LOCATION/BIL.
# output files are named raster.hdr, raster.bilw, raster.bil
# original script by T. D'Avello 12/18/97.
# Modifications by Jill Schuler  5/6/98
# (Color schemes in GRASS won't replicate in AV)
name=$1
outname=$2
if test "$name" = "help"; then
echo "Usage: `basename $0` name outname
where:
name = GRASS raster file name
outname = BIL raster file name
Output files are stored under the \$LOCATION/BIL directory and named with the
original raster name using the following extensions (.bil .bilw .hdr )
exit
fi
# Make directory "BIL" to store resulting files
if [ ! -d $LOCATION/BIL ]
     then
     mkdir $LOCATION/BIL
fi
if [ "${name}" = "" ]; then
  echo "Collecting the GRASS raster name for conversion............  "
  g.ask type=old element=cell desc="GRASS raster" unixfile=tmp
  . tmp
  if test "$name" = "";then exit;fi
else
  g.findfile element=cell file=$name >tmp
  . tmp
fi
while test "$outname" = ""; do
echo
echo -n "Enter the output ROOT name (the extension .bil will be appended)
read outname
if test -f $LOCATION/BIL/$outname.bil; then
echo
echo "File name $outname already exists under the BIL directory."
echo -n "Overwrite? ([y]es or (n)o): "
read ans
ans=${ans:-y}
  if [ "$ans" = "n" -o "$ans" = "N" ]; then
  outname=""
  fi
fi
done
name_mapset=`grep "^mapset=" tmp |cut -d "=" -f 2 | sed -e "s/'//g"`
if [ ! -s $LOCATION/../$name_mapset/cellhd/${name} ]
   then
	echo "ERROR:  File not found"
	echo "ERROR:  Exiting................"
	exit 5
fi
# Check for existing files under the BIL dir and delete
for i in BIL/$outname.hdr BIL/$outname.bilw BIL/$outname.bil BIL/$outname.txt
do
if test -f $LOCATION/$i; then
echo
echo "Removing existing $i"
rm $LOCATION/$i
fi
done
#######set variables for conversion of raster
cell=$LOCATION/../$name_mapset/cellhd
#  Get info from cellhd for bilw and hdr
#  collect information from the GRASS cellhd file
#  GRASS cellhd format
#  proj:       1
#  zone:       11
#  north:      5265300
#  south:      5249500
#  east:       717600
#  west:       706600
#  cols:       11000
#  rows:       15800
#  e-w resol:  1
#  n-s resol:  1
#  format:     0
#  compressed: 1
#test for reclass file format and resample
reclass=`grep "^reclass$" $cell/$name | awk '{print $1}'`
if test "$reclass" = "reclass"; then
echo
echo "This raster file is a Reclass file and must be saved as a real raster."
echo "The current geographic region and resolution will be used.
Additionally, if a MASK is set, the raster will be clipped to the mask."
r.resample input=$name output=$name.tmp
name=$name.tmp
name_mapset=$MAPSET
fi
proj=`grep "proj:" $LOCATION/../PERMANENT/PROJ_INFO | awk '{print $2}'`
ellps=`grep "ellps:" $LOCATION/../PERMANENT/PROJ_INFO | awk '{print $2}'`
units=`grep "units:" $LOCATION/../PERMANENT/PROJ_UNITS | awk '{print $2}'`
if test -f $LOCATION/../PERMANENT/DATUM_INFO; then
nad=`grep "datum:" $LOCATION/../PERMANENT/DATUM_INFO | awk '{print $2}'`
region=`grep "region:" $LOCATION/../PERMANENT/DATUM_INFO | awk '{print $2}'`
else
nad=nad27
region=conus
fi
zone=`grep "zone:" $cell/$name | awk '{print $2}'`
res=`grep "e-w resol:" $cell/$name | awk '{print $3}'`
col=`grep "cols:" $cell/$name | awk '{print $2}'`
row=`grep "rows:" $cell/$name | awk '{print $2}'`
nrt=`grep "north:" $cell/$name | awk '{print $2}'`
wst=`grep "west:" $cell/$name | awk '{print $2}'`
compress=`grep "compressed:" $cell/$name | awk '{print $2}'`
# check for compression status and uncompress if needed
echo
 if [ "$compress" -eq 1 ]
   then
     echo "Uncompressing GRASS file and copying raster............"
   if test "$MAPSET" != "$name_mapset"; then
     g.copy rast=$name,$name.tmp >/dev/null 2>&1
     r.compress -u map=$name.tmp >/dev/null 2>&1
     cp $LOCATION/cell/$name.tmp $LOCATION/BIL/$outname.bil
     g.remove rast=$name.tmp >/dev/null 2>&1
   else
     r.compress -u map=$name >/dev/null 2>&1
     cp $LOCATION/cell/$name $LOCATION/BIL/$outname.bil
   fi
 else
  echo "Copying GRASS raster file............"
  cp $LOCATION/../$name_mapset/cell/$name $LOCATION/BIL/$outname.bil
 fi
# Write text file
echo
echo "Writing .txt file with projection information............................"
echo "projection $proj" >> $LOCATION/BIL/$outname.txt
echo "datum $nad" >> $LOCATION/BIL/$outname.txt
echo "region $region" >> $LOCATION/BIL/$outname.txt
echo "zone $zone" >> $LOCATION/BIL/$outname.txt
echo "ellpsoid $ellps" >> $LOCATION/BIL/$outname.txt
echo "units $units" >> $LOCATION/BIL/$outname.txt
# Write Header file
echo
echo "Writing .hdr file............................"
echo "nrows $row" >> $LOCATION/BIL/$outname.hdr
echo "ncols $col" >> $LOCATION/BIL/$outname.hdr
echo "nbands 1" >> $LOCATION/BIL/$outname.hdr
echo "nbits 8" >> $LOCATION/BIL/$outname.hdr
echo "layout bil" >> $LOCATION/BIL/$outname.hdr
echo "skipbytes 0" >> $LOCATION/BIL/$outname.hdr
echo "bandrowbytes $col" >> $LOCATION/BIL/$outname.hdr
echo "totalrowbytes $col" >> $LOCATION/BIL/$outname.hdr
# Variables for world file
# Write World file
echo
echo "Writing World file............................"
ulx=`echo $wst $nrt $res | awk '{ printf("%f",$1+($3*0.5)) }'`
uly=`echo $wst $nrt $res | awk '{ printf("%f",$2-($3*0.5)) }'`
echo "$res" >> $LOCATION/BIL/$outname.bilw
echo "0.0" >> $LOCATION/BIL/$outname.bilw
echo "-${res}" >> $LOCATION/BIL/$outname.bilw
echo "$ulx" >> $LOCATION/BIL/$outname.bilw
echo "$uly" >> $LOCATION/BIL/$outname.bilw
echo
echo "Removing temporary raster file $name"
g.remove rast=$name >/dev/null 2>&1
fi
echo
echo "The following files were generated under your current Location:"
ls $LOCATION/BIL/$outname.*
# file for display in ArcView or ArcInfo as a "geotiff" file.
# files are stored under $LOCATION/TIFF.
# output files are named raster.tfw, raster.tif, raster.txt
# Script by Jill Schuler  5/6/98
# USAGE: rast.to.geotiff <raster_file>
name=$1
outname=$2
where:
outname = GeoTIFF file name
Output files are stored under the \$LOCATION/TIFF directory and named with the
original raster name using the following extensions (.tif .tfw .txt )
exit
fi
# Make directory "TIFF" to store resulting files
if [ ! -d $LOCATION/TIFF ]
     then
     mkdir $LOCATION/TIFF
fi
  . tmp
else
  . tmp
fi
   then
	echo "ERROR:  Cellhd File not found"
	exit 5
fi
echo
echo -n "Enter the output ROOT name (the extension .tif will be appended)
read outname
if test -f $LOCATION/TIFF/$outname.tif; then
echo "File name $outname already exists under the TIFF directory."
read ans
ans=${ans:-y}
  outname=""
  fi
fi
done
# Check for existing files under the TIFF dir and delete
for i in $name.txt $name.tfw $name.tif
do
if test -f $LOCATION/TIFF/$i; then
rm $LOCATION/TIFF/$i
fi
done
#  Get info from cellhd for tfw and.txt
#  proj:       1
#  zone:       11
#  north:      5265300
#  south:      5249500
#  east:       717600
#  west:       706600
#  cols:       11000
#  rows:       15800
#  e-w resol:  1
#  n-s resol:  1
#  format:     0
#  compressed: 1
echo
name=$name.tmp
name_mapset=$MAPSET
fi
else
nad=nad27
region=conus
fi
#echo "Displaying the $cell/$name file"
#read dummy
#cat $cell/$name
#read dummy
#echo "<$res $col $row $nrt $wst $compress>"
echo
echo "Generating the TIFF file using r.out.tiff"
r.out.tiff -pv input=$name output=$outname.tif
mv $outname.tif $LOCATION/TIFF/$outname.tif
# Write Header file
echo
echo "Writing .txt file............................"
echo "projection $proj" >> $LOCATION/TIFF/$outname.txt
echo "nad $nad" >> $LOCATION/TIFF/$outname.txt
echo "region $region" >> $LOCATION/TIFF/$outname.txt
echo "zone $zone" >> $LOCATION/TIFF/$outname.txt
echo "ellpsoid $ellps" >> $LOCATION/TIFF/$outname.txt
echo "units $units" >> $LOCATION/TIFF/$outname.txt
echo "nrows $row" >> $LOCATION/TIFF/$outname.txt
echo "ncols $col" >> $LOCATION/TIFF/$outname.txt
echo "nbands 1" >> $LOCATION/TIFF/$outname.txt
echo "nbits 8" >> $LOCATION/TIFF/$outname.txt
echo "format uncompressed" >> $LOCATION/TIFF/$outname.txt
echo "bandrowbytes $col" >> $LOCATION/TIFF/$outname.txt
echo "totalrowbytes $col" >> $LOCATION/TIFF/$outname.txt
# Write World file
echo
echo "$res" >> $LOCATION/TIFF/$outname.tfw
echo "0.0" >> $LOCATION/TIFF/$outname.tfw
echo "-${res}" >> $LOCATION/TIFF/$outname.tfw
echo "$ulx" >> $LOCATION/TIFF/$outname.tfw
echo "$uly" >> $LOCATION/TIFF/$outname.tfw
echo
fi
echo
ls $LOCATION/TIFF/$outname.*
