v.digit and snapping
    Malcolm Williamson
    malcolm at cast.uark.edu
    Wed Dec 23 10:15:05 EST 1998
Hi, Markus
Changing the snapping threshold _should_ help. Don't forget that you're
working in "digitizer" inches - you'll need to multiply the threshold by
your scale to get equivalent ground distance.
If this still isn't helping, use the "snap to line" command in the Edit menu.
You can also specify a snapping threshold in v.support, though this is a
little risky. Save a backup copy before doing this, in case it snaps
lines that you didn't intend to!!
Best holiday wishes,
	-Malcolm
On Wed, 23 Dec 1998, Markus Neteler wrote:
> Hi,
> usually I am working raster-oriented, so I have questions
> concerning snapping nodes in v.digit:
> When digitizing a polygon (with mouse digitizer), how to
> make the end nodes of a polygon to be snapped automatically?
> Changing the snapping distance didn't help (and using always
> the Edit menu is a ot of extra work). What did I miss?
> I need the polygons to be closed.
> Markus
