problems with g.mapsets
ish at alla.pl.swf.usace.army.mil
Thu Jan 8 14:30:46 EST 1998
> Hello list readers,
> recently we have the problem that the command g.mapsets isn=B4t working =
> anymore. If I call it I get the message:
> "MAPSET SEARCH LIST UTILITY LOCATION: Elbeprojekt MAPSET: spree
> Your mapset search list:
> spree not found in mapset list: call greg
> Mapset <spree> in Location <Elbeprojekt>"
> Does anybody know what went wrong.
> Thanks in advance
> Peter
Peter
The g.mapset utility looks for mapsets in the LOCATION directory
specified by the user when starting GRASS. Is it possible that
your user started GRASS with another LOCATION designated? You
could try running g.mapsets interactively to see what mapsets
are found for the LOCATION you are working in. If you can cd to
$LOCATION and list the mapset directory then it should be accessible
with the g.mapsets utility. Good luck.
Ishmael Williams
US Army Corps of Engineers
Fort Worth District
Fort Worth, Texas
email: ish at alla.pl.swf.usace.army.mil
