Floating point code problems
Justin Hickey
jhickey at impact1.hpcc.nectec.or.th
Wed Jan 14 05:06:23 EST 1998
Hello all
I asked this question before close to Christmas and never received an answer,
so I'll ask again in case some people missed it. My apologies to those who read
this before and cannot help me.
We recently compiled the floating point code for grass and am trying to convert
vector files to raster files. First we import them from ArcInfo using v.in.arc
and all seems to work fine with that command. However, when we run v.to.rast,
on each pass of the program we get the following warning:
WARNING: Calling G_set_window() in the middle of writing map soil
The program still continues and eventually finishes, however when we display
the new file with d.rast nothing appears on the screen and d.what.rast
indicates that all values (I assume this since I didn't check each cell) are
Null and contain no data. Note that we used the vector map to indicate the
correct part of the map.
For what it's worth the warning is generated from
$GIS/src/libes/gis/set_window.c (function G_set_window)
and G_set_window is called from
$GIS/src/mapdev/v.to.rast/raster.c
The data is fine since we converted the same file from ArcInfo to vector to
raster using the original Grass code (ie without the floating point code) on
another machine. This produced a correct raster map.
Does anyone have any ideas about what is wrong? Has anyone experienced this
problem before?
Also, we found that r.mask and r.reclass do not work with the floating point
version. In this case, a memory allocation error (not enough memory) is
reported but there is at least 200MB of RAM available. The error is generated
even on a small 5x5 cell test raster map. Any ideas about this one?
Any help would be greatly appreciated, even if it is to simply confirm whether
someone else using the floating point version of grass has similar problems or
not. Thank you in advance for your time and effort in this matter.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
