dxf to polygons
Andrea Giacomelli andreag at crs4.it
Mon Jan 19 13:34:55 EST 1998
I need to import some DXF files to GRASS.
With linear themes, the v.in.dxf3d does an excellent job; with
polygon themes I have problems in reconstructing the proper polygons via
v.digit.
I can first of all "re-type" arcs from line to area; however,
when I pass to assigning labels, the process succeeds only if the
polygon is composed by 1 or 2 arcs (otherwise v.digit says it
is not able to define a polygon).
At any rate, reconstructing the polygons manually can become very
time consuming.
I have re-checked the documentation on v.in.dxf and v.cadlabel,
and I see that there is no mentioning of polygon themes...
So: is it possible to reconstruct automatically a polygon from a DXF polyline ?
Maybe with polylines defining the arcs and text labels positioned
inside the polygons ?
I will be grateful for any hints !
                Andrea Giacomelli
                Centre for Advanced Studies, Research and
                Development in Sardinia
                Environment Division
                http://www.crs4.it/~andreag
