surface area
Malcolm Williamson
malcolm at cast.uark.edu
Wed Jan 21 11:12:35 EST 1998
On Wed, 21 Jan 1998, Angus Carr wrote:
> First, calculate the surface areas of individual cells using a slope map,
> then generate a sum of the cell values, using r.stats and a spreadsheet.
r.stats -1z input=surface_area_map | awk '{ areasum+=$1 } END{ print
areasum}'
will save you from having to export to a spreadsheet.
-Malcolm
> Good Luck
> Angus.
> On Tue, 20 Jan 1998, Frank Lederer wrote:
> > Hi GRASS community,
> > is it possible to calculate the surface area of a 3d (not 2d!!) surface (DEM)?
> > Thanks in advance
> > Frank
> > Frank Lederer
> > Sandweg 64
> > 60316 Frankfurt/Main
> > Germany
> > Lederer at em.uni-frankfurt.de
> > phone: ++49-069-4960545
