ps.map - linux
Justin Hickey
jhickey at impact1.hpcc.nectec.or.th
Wed Jan 28 04:28:55 EST 1998
Hi Anthony
On Jan 27, 12:26pm, anthony burns wrote:
> Subject: ps.map - linux
> Linux grass users
> I ps.select the printer driver ie hp650D, a3 or whatever, it accepts it just
> fine. I then use ps.map to develop the map. After I respond to all questions
> and give a file name to output the map, the process begins , I see ps.map
select
> the printer and then it immediately core dumps with a segmentation fault.
> Any ideas as to what the problem is.
> Thanks
> Anthony
>-- End of excerpt from anthony burns
You may want to try the bug fix on the GRASS FAQ page
(http://www.cecer.army.mil/grass/faq.html), question 12 - there is a fix for
the ps.select command. Although the bug caused different results (the command
quit with an error message - no core dump) on our system, your problem may be
the same bug.
Hope this helps.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
