Conversion of GTOPO30
Jason Sperfslage
jasperfs at hrc.ucsd.edu
Fri Jul 24 12:36:33 EDT 1998
Hi Stephan,
Perhaps your problem more complicated than I think, but here is what I have
done in similar situations:
1) Import each image independently, just use the original resolution and region
for each one.
2) Now edit your region to the be entire area of interest and the final
resolution of interest.
3) Use r.mapcalc to merge the images together into the new window/resolution.
g.region region=big.region
r.mapcalc "newimage1 = gtopoimage1"
r.mapcalc "newimage2 = gtopoimage2"
r.mapcalc "bigimage = max(newimage1,newimage2)"
It's been some time since I've done this, so maybe/maybe not - it should only
take a minute or two to test it. You could probably even skip the separate
resamplings of gtopoimage*, and just do the "max" on them directly. I don't
know if you need more elaborate sampling than this, but both images are gridded
rasters, you shouldn't need to go to points and then surf the points together -
I know how slow that can be! When you redefine a raster with r.mapcalc it will
resample to the resolution of the currently defined region. You can use this
to sample up to a coarser resolution too, if you don't mind having point samples
from the original data.
Hope this helps - let me know.
Best regards,
Jason
___________________________________________________________________________
HRC is a Non-Profit Research Corporation, Established 1993
Jason A. Sperfslage Hydrologic Research Center
System Administrator/Programmer 12780 High Bluff Drive, Suite 250
San Diego CA 92130-2069
jasperfs at hrc.ucsd.edu Tel: (619) 794-2726
Fax: (619) 792-2519
http://hrc.ucsd.edu
