converting sites files to another coordinate system!!
    Jill Schuler
    jschuler at tulip.itc.nrcs.usda.gov
    Mon Jun  1 14:02:23 EDT 1998
Use the USGS PROJ command to convert your sites.  Download the following
tar file from:
ftp ftp.itc.nrcs.usda.gov:applications/mapgen/GRASS_SOFT/proj.sites.tar.gz
ftp ftp.itc.nrcs.usda.gov:applications/mapgen/GRASS_SOFT/README.proj.sites
ftp.itc.nrcs.usda.gov = 162.79.104.20
usage: proj.sites file outfile proj ellps other
where:
file is the name of the site_lists file to project
outfile is the full path name for the new projected site file
proj is the output projection abbreviation (use proj -lp for projection names)
ellps is the output ellipsoid abbreviation (use proj -le for ellipsoid names)
other are other projection options in the proj key word format
      (for example: +zone= +lat_0= +lon_0= +lat_1= +lat_2= +lon_1= +lon_2=
       +x_0= +y_0= +k=) Note: if more than one option used embed in quotes (")
      ("+lat_0=45.0 +lon_0=-96.0")
The output file is placed under your current directory or the location defined
by the full path.
Jill
Jill R. Schuler                                     / \
USDA Natural Resource Conservation Service        /.....\/\    /\
2627 Redwing, Suite 120                          /       \_/\_/  \
Ft. Collins, Co 80526                         /\/             _/\ ---------
_____________________________________________/
FAX:970-282-1930   VCOMM:9010-2418   PHONE:970-282-2418
e-mail:jschuler at itc.nrcs.usda.gov
"A map is the greatest of all epic poems.  Its lines and colors show the
realization of great dreams."  Gilbert Grosvenor, National Geographic Editor
