probleme opening monitors
Angus Carr
apcarr at FLASH.LakeheadU.CA
Thu Jun 25 22:47:30 EDT 1998
You are using a 24-bit X server with an 8-bit GRASS Monitor.
Try using the XDRIVER24 program instead. If you change etc/monitorcap,
things will work.
Good luck.
Angus Carr.
On Thu, 25 Jun 1998, Karine ZUERCHER wrote:
> Hey everybody!
> I've already got another probleme: I can't open any monitors.
> I'm working on a PC, not connected to any network and with linux installed
> just now to work with GRASS.
> Here's the message I get when trying to start the monitors (d.mon):
> name description status
> x0 X-windows graphics display not running
> x1 X-windows graphics display not running
> x2 X-windows graphics display not running
> x3 X-windows graphics display not running
> x4 X-windows graphics display not running
> x5 X-windows graphics display not running
> x6 X-windows graphics display not running
> CELL Create GRASS Raster File not running
> X Error of failed request: BadMatch (invalid parameter attributes)
> Major opcode of failed request: 78 (X_CreateColormap)
> Serial number of failed request: 30
> Current serial number in output stream: 31
> Please start graphics monitor <x0>.
> Error - Graphics monitor <x0> not running!
> Problem selecting x0. Will try once more
> Thanks a lot if you could help
> karine
> \ Karine ZUERCHER zuercher at sc2a.unige.ch /
> / University of Geneva \
