probleme opening monitors
Markus Neteler
neteler at geog.uni-hannover.de
Fri Jun 26 09:19:09 EDT 1998
Hi all,
> x5 X-windows graphics display not running
> x6 X-windows graphics display not running
> CELL Create GRASS Raster File not running
> X Error of failed request: BadMatch (invalid parameter attributes)
> Major opcode of failed request: 78 (X_CreateColormap)
> Serial number of failed request: 30
> Current serial number in output stream: 31
you can use GRASS with 8bit as well as 24bit. You just have
to set the link in grass42/driver to the proper driver.
The message "X_CreateColormap" indicates that the link is
currently set to the wrong GRASS-Xdriver.
Available are the following Xdriver:
ls -la /grass42/driver/
drwxrwxrwx 2 neteler user 512 Jun 25 17:15 .
drwxr-xr-x 13 neteler user 512 Jun 25 17:15 ..
-rwxrwxr-x 1 neteler user 96364 Jun 25 17:15 CELL
lrwxrwxrwx 1 root other 9 Jun 15 15:21 XDRIVER -> XDRIVER_8
-rwxr-xr-x 1 neteler user 41880 Apr 2 10:59 XDRIVER_24
-rwxr-xr-x 1 neteler user 41660 Apr 2 10:59 XDRIVER_8
The link MUST certainly fit to the configuration of XSERVER of
your Linux/SUN/HP, whatever you use. Getting this error message,
you either change the color depth of your X11-XSERVER or the link
onto the GRASS driver.
Hope this helps
Markus Neteler
Geographisches Institut | Institute of Geography
Physische Geographie Physical Geography
& Landschaftsoekologie & Landscape Ecology
Universitaet Hannover University of Hannover, Germany
http://www.geog.uni-hannover.de/users/neteler/
