functional list of GRASS commands -Reply
anthony burns KY#c#KY.BLNKY01#c#agburns at KCC.FSA.USDA.GOV
Fri Mar 13 16:11:10 EST 1998
GRASS users
As requested, attached is a list of the commands and scripts that I put together
from the  GRASS4.2.1 source code that  I downloaded from the
laum.uni-hannover.de/iln site.  It is just a list of commands  with a reference
to whether it is a main, alpha, or contributed code and the contributing source.
Anthony Burns
agburns at kcc.fsa.usda.gov
GRASS4.2 command and script list
The list is based on commands compiled from
GRASS4.2.1 source code (beta 6) obtained from
Anthony Burns
USDA-NRCS
GIS Specialist
Burlington, KY
agburns at kcc.fas.usda.gov
GRASS scripts
	d.view.sh		script
	blend.sh		script
	bug.report.sh		script
	dcorrelate.sh		script
	demo.scripts		script
	demo.sh			script
	grass.logo.sh		script
	hsv.rgb.sh		script
	intens.sh		script
	rgb.hsv.sh		script
	shade.clr.sh		script
	shale.rel.sh		script
	show.color.sh		script
	slide.slo.sh		script
	split.sh		script
	start.man.sh		script
	iger.info.sh		script
	v.in.dxf3d.sh		script
	v.line2area.sh		script
COMMANDS
d.3d
d.area			extra from laum.uni-hannover.de/iln
d.ask
d.barscale		extra from laum.uni-hannover.de/iln
d.colormode
d.colors
d.colortable
d.display
d.erase
d.fix_ortho		NRCS contributed
d.font
d.frame
d.geodesic
d.graph
d.grid
d.his
d.histogram
d.icons
d.label
d.labels		alpha
d.legend
d.linegraph		PURDUE contributed
d.mapgraph
d.measure
d.menu
d.mon
d.myzoom		extra from laum.uni-hannover.de/iln
d.p.labels
d.pan			extra from laum.uni-hannover.de/iln
d.param.scale		extra from laum.uni-hannover.de/iln
d.points
d.profile
d.rast
d.rast.arrow 		alpha
d.rast.edit		alpha
d.rast.num 		alpha
d.rast.zoom		alpha
d.rgb
d.rgbcolortbl		extra from laum.uni-hannover.de/iln
d.rhumbline
d.save
d.scale
d.sites
d.text
d.title
d.vect
d.vect.cats		CAST contributed
d.vect.zoom		extra from laum.uni-hannover.de/iln
d.what.rast
d.what.vect
d.where
d.zoom
g.access
g.ask
g.filename
g.findfile
g.gisenv
g.manual
g.mapsets
g.region
g.setproj
g.tempfile
g.version
geom-package		extra from laum.uni-hannover.de/iln
grass.to.ipw		EPA contributed (not compiled)
i.ask
i.cca
i.class
i.cluster		alpha
i.colors
i.composite
i.fft
i.find
i.gensig		alpha
i.gensigset		alpha
i.grey.scale
i.group
i.in.erdas		alpha
i.maxlik
i.ortho.photo		alpha
i.pca
i.points
i.quantize		alpha
i.rectify
i.rectify2		alpha
i.rgb.his
i.rvi.prediction2	CERL contributed (not compiled)
i.shape			CERL contributed
i.smap			alpha
i.tape.mss
i.tape.mss.h
i.tape.other
i.tape.spot		alpha
i.tape.tm
i.tape.tm.fast		alpha
i.target
i.texture		PURDUE contributed
i.vpoints		alpha
i.zc
ipw.to.grass		EPA contributed ( not compiled)
m.datum.shift
m.dem.examine
m.dem.extract		alpha
m.dmaUSGSread
m.dted.examine
m.dted.extract
m.eigensystem		CERL contributed
m.examine.tape
m.flip			alpha
m.gc2ll
m.in.pl94.db3		alpha
m.in.stf1.db3		alpha
m.in.stf1.tape		alpha
m.ll2gc
m.ll2u
m.lulc.read		alpha
m.lulc.USGS		alpha
m.proj			alpha
m.region.ll
m.regression		CERL contributed
m.rot90
m.tiger.region		alpha
m.u2ll
moss			alpha
p.map.new/cmd		alpha
ps.map			alpha
r.affinity		extra from laum.uni-hannover.de/iln
r.agnps			GRASS4.2 AGNPS 5.0  alpha
r.average
r.basins.fill
r.bilinear		GRASS4.2 alpha
r.binfer
r.buffer
r.casc2d		GRASS4.2 alpha
r.cats
r.clump
r.clump1		extra from laum.uni-hannover.de/iln
r.cn			GRASS4.2 alpha
r.coin
r.colors
r.colors.paint		alpha
r.colors.paint		CAST contributed
r.combine
r.compress
r.contour		alpha
r.cost			alpha
r.covar
r.cross
r.describe
r.digit			alpha
r.drain
r.feat.thin		extra from laum.uni-hannover.de/iln
r.flow			extra from laum.uni-hannover.de/iln
r.flow			GRASS4.2 alpha
r.frac.surf		extra from laum.uni-hannover.de/iln
r.gauss.surf		extra from laum.uni-hannover.de/iln
r.grow
r.in.ascii
r.in.doq		NRCS contributed
r.in.erdas		NRCS contributed
r.in.gif		extra from laum.uni-hannover.de/iln
r.in.hdf		GRASS4.2 alpha  (not compiled)
r.in.ll
r.in.poly		alpha
r.in.sunrast		alpha
r.in.utm		NPS contributed
r.infer
r.info
r.kappa			extra from laum.uni-hannover.de/iln
r.kineros		extra from laum.uni-hannover.de/iln
r.lags			extra from laum.uni-hannover.de/iln
r.le			GRASS4.2 alpha
r.line			alpha
r.linear.regression	CERL contributed
r.los
r.mapcalc
r.mask.points		alpha
r.median		alpha
r.mfilter
r.mode			alpha
r.moran			extra from laum.uni-hannover.de/iln
r.ndvi.model		CERL contributed
r.neighbors
r.nntool		GRASS4.2 alpha
r.out.ascii
r.out.ascii		PURDUE contributed
r.out.mpeg		GRASS4.2 alpha
r.out.ppm		GRASS4.2 alpha
r.out.tga		alpha
r.param.scale		extra from laum.uni-hannover.de/iln
r.patch
r.poly
r.profile
r.rand.surf		extra from laum.uni-hannover.de/iln
r.random
r.rational.regression	CERL contributed
r.reclass
r.report
r.resample
r.rescale
r.rescale.eq		alpha
r.rvi			CERL contributed  (not compiled)
r.slope.aspect
r.stage3		GRASS4.2 alpha (not compiled)
r.statistics		extra from laum.uni-hannover.de/iln
r.stats
r.sun			GRASS4.2 Alpha
r.support
r.surf.contour		alpha
r.surf.idw
r.surf.idw2
r.tangent		NRCS contributed
r.thin			alpha
r.tiff			extra from laum.uni-hannover.de/iln
r.traj			CERL contributed  (not compiled)
r.transect
r.tribs			extra from laum.uni-hannover.de/iln
r.volume
r.water.fea		GRASS4.2 alpha
r.water.outlet.3.0	extra from laum.uni-hannover.de/iln
r.watershed
r.weight
r.weight2		alpha
r.what
r.xy			extra from laum.uni-hannover.de/iln
s.buffer		extra from laum.uni-hannover.de/iln
s.dotmap.new		NRCS contributed  (not compiled)
s.in.ascii
s.label			extra from laum.uni-hannover.de/iln
s.medp			PURDUE contributed
s.menu
s.nearest		extra from laum.uni-hannover.de/iln
s.out.ascii
s.surf.idw
s.surf.krig		extra from laum.uni-hannover.de/iln
s.surf.tps		alpha
s.to.rast		GRASS4.2 alpha
s.to.rast 		OTHER contributed (not compiled)
s.to.vect		GRASS4.2 alpha
s.voronoi		PURDUE contributed
s.windavg		extra from laum.uni-hannover.de/iln
v.alabel		alpha
v.apply.census		alpha
v.area
v.autocorr		PURDUE contributed
v.build
v.cadlabel
v.circle		GRASS4.2 alpha
v.clean
v.cutter		alpha
v.digit
v.dump			NRCS contributed
v.extract		NRCS contributed
v.from.3
v.import
v.in.arc		alpha
v.in.ascii
v.in.dlg
v.in.dxf
v.in.dxf3d		GRASS4.2 alpha
v.in.poly/cmd		OTHER contributed (not compiled)
v.in.tig.basic		alpha
v.in.tig.lndmk		alpha
v.in.transects		alpha
v.info			GRASS4.2 alpha
v.make.subj		NRCS contributed
v.merge			NRCS contributed
v.mkgrid
v.mkgrid		PURDUE contributed
v.mkquads		NRCS version
v.mkquads		orig version copied to v.mkquads.bak in  etc/bin/main/cmd
v.out.arc		alpha
v.out.dlg
v.out.dxf
v.out.idrisi		GRASS4.2 alpha
v.patch
v.proj			alpha
v.proj			NRCS contributed  (not compiled)
v.prune
v.reclass		alpha
v.report		NRCS contributed
v.rmedge		NRCS contributed
v.spag
v.stats
v.support
v.surf.spline		extra from laum.uni-hannover.de/iln
v.to.rast
v.to.sites		alpha
v.transform
v.trim
v.what			extra from laum.uni-hannover.de/iln
