Problem on compiling grass4.2
John Charles Welch
jcwelch at infohwy.com
Fri Mar 13 23:04:11 EST 1998
Pan Daiyan wrote:
> Hello,
> [ problem snipped]
> I would appreciate any helps.
> Thanks.
> Daiyuan Pan
I have a similar but different problem on RedHat Linux 4.2 I think that
mine may be related to curses, but have not had time to really hack on
it, yet I listed the output below.
If anyone has had this problem please let me know.
GISBASE=/usr/local/grass42
SRC=/usr/local/grass42/src421/src
CMD=/usr/local/grass42/src421/src/CMD
HEADER=linux
ARCH=linux
GISGEN Fri Mar 13 21:59:43 CST 1998
GISBASE = /usr/local/grass42
SRC = /usr/local/grass42/src421/src
CMD = /usr/local/grass42/src421/src/CMD
HEADER = linux
ARCH = linux
first step: src/display/d.3d
GISGEN: src/display/d.3d - Fri Mar 13 21:59:46 CST 1998
/home/john/grass/src421/src/display/d.3d
make -f OBJ.linux/make.rules
gcc -s -o /usr/local/grass42/etc/bin/main/inter/d.3d OBJ.linux/main.o
OBJ.linux/threed.o OBJ.linux/transform.o OBJ.linux/clip.o
OBJ.linux/get_range.o OBJ.linux/check_opt.o OBJ.linux/get_inputs.o
OBJ.linux/sigint.o OBJ.linux/get_row.o OBJ.linux/draw_face.o
/usr/local/grass42/src421/src/libes/LIB.linux/libD.a
/usr/local/grass42/src421/src/libes/LIB.linux/libdisplay.a
/usr/local/grass42/src421/src/libes/LIB.linux/libraster.a
/usr/local/grass42/src421/src/libes/LIB.linux/libgis.a
/usr/local/grass42/src421/src/libes/LIB.linux/libvask.a -lcurses -lm
ld: cannot open -lcurses: No such file or directory
make: *** [/usr/local/grass42/etc/bin/main/inter/d.3d] Error 1
GISGEN failure at STEP: src/display/d.3d
[john at jcwelch CMD]$
