Help using v.in.dxf3d
Ben Horner-Johnson
ben at earth.nwu.edu
Mon Nov 30 16:34:28 EST 1998
The code for v.in.dxf looks like it handles Z coordinates. The problem with
the v.in.dxf code is that it converts attributes/labels into integers because
it uses the write_att() structure from the dig_atts libraries which convert
labels into categories, which are by default integer. If a label in a dxf file
contains non-integers, it will be truncated.
(i.e. "001_bz3.cat" becomes "1"). I tried modifying v.in.dxf to handle the
text properly (it did) but when I ran v.support, it switched things back to
integers. I haven't released modifications because of this problem. I don't
know if this is part of the problem you are having, but thought I should
mention what I found out.
Ben Horner-Johnson
