How to clip image...
Luis Blanco
lblanco at anaya.es
Fri Oct 2 03:48:04 EDT 1998
Hi, taravudh...
I got the same problem when i began to use grass. The solution is as follow:
Set the region (your geographic window) to the desired area
g.region n=<value> s=<value> e=<value> w=<value> res=<value>
check the resolution parameters, in general don´t use it for making clops,
the image (raster file)
get resampled; but it is ok for testing.
r.mapcalc file.dst=file.src
this command make the crop, other way is:
r.patch out=file.dst in=file.src,file.src
that is make a patch of a raster with it self.
Hope this help you.
#Luis Blanco
#Grupo Anaya
#Juan Ignacio Luca de Tena, 15
#28027 Madrid, SPAIN
#tel.: 34 91 393 88 39
#fax.: 34 91 742 66 31
#e-mail: lblanco at anaya.es
