Exporting dxf with elevation?
Andreas Bullinger
bullinger at geographie.uni-kiel.de
Tue Oct 13 06:58:10 EDT 1998
I'm trying to export a contour map from Grass to Autocad (12/14). I made
a contour map with r.contour, transformed the binary vector to ascii and
exported to dxf with v.out.dxf. The polylines are ok, but they have the
elevation zero.
In the WEB I found the hint:
sort +3n -4 in_file > in_file.sort
join -j1 4 -j2 1 -o 1.1 .1.2 1.3 2.1 in_file.sort file2 > file.join
#in_file is a dig_att file that must be sorted for join to work
#file.join will be th new dig_att file to trick GRASS into providing dxf
files with actural polygon labels . Rename corresponding GRASSfiles to
match file.join
The sort command seems to work. Does anyone know what file2 should be?
What corresponding GRASSfiles have to be renamed?
Does anyone know a module for Grass exporting dxf Files with elevation?
Thanks
Andreas Bullinger
