GRASS lock problem
Markus Neteler
neteler at geog.uni-hannover.de
Wed Apr 14 16:09:07 EDT 1999
> >/usr/local/grass42/etc/GIS.sh: /usr/local/grass42/etc/lock: No such file
> > or directory
> >Unable to properly access /home/hamannj/.gislock
> >Please notify system personel.
> >[hamannj at ren hamannj]$ =
> >I installed the grass binaries exactly as instructed from the web site and
> >still get this problem. =
> Several of us are getting that exact error message ( with our own machine n=
> ame,
> of course). I don't know what to try next, but I believe Markus is
> looking into it (see quote below).
> > > We will find a solution!
Hi friends,
just now I have installed GRASS 4.2.1 (V.21) on a "fresh" Linux System
running SuSe6.0-Linux.
But I could not reproduce your error message. I downloaded the current
Linux binaries and strickly followed my instructions (without extra
knowledge!).
So we have to proceed stepwise to locate the problem. You may post
personally to me, I will send the solution to the list then, when
(not if) we find it:
1. Are you all running *Redhat* Linux? Which version?
2. Is there existing the file
Execute it, it should say
/usr/local/grass42/etc > lock
usage: lock file pid
3. Check the permissions for /usr/local/grass42/locks
/usr/local/grass42 > ls -la locks/
total 3
drwxrwxrwt 4 root root 1024 Apr 14 15:40 .
drwxr-xr-x 13 root root 1024 Apr 14 15:38 ..
drwxrwxrwt 2 root root 1024 Apr 14 15:43 ifbo22
It should look like this (with different machine's name certainly)
BTW: Valid are the online instructions. I changed this part of
locks permission settings recently, so it may not be correct in
the instructions included in the Linux package.
4. Check the permissions of your home directory:
cd $HOME
akk at ifbo22:~ > ls -la .
drwxr-xr-x 17 akk users 2048 Apr 14 15:49 .
drwxr-xr-x 8 root root 1024 Feb 10 19:03 ..
Here it belongs user "akk", certainly he needs write/read/execute
permissions (first drwx in line containing ".").
This should be o.k.
Test it in your home with
touch .gislock
rm .gislock
This should work.
Is there any other user in the list having an idea? I haven't seen
this problem yet in my "GRASS life".
With regards
Markus Neteler
