We can't import more than 49 files
Utente Grass grass at meteux.ismaa.it
Thu Apr 22 06:17:33 EDT 1999
On mer, 21 apr 1999, you wrote:
> As far as I know GRASS has not realistic limit for the number of mapsets
> that are allowed.  I have created directories with hundreds of maps with
> no problem.  Instead could this be a disk space related error you are having?
> R. Joe
> On Wed, 21 Apr 1999, Utente Grass wrote:
> > S.Michele 21.IV. 99  Italy
> > We are only beginers; we created a little program to import automatically 215
> > files ascii in GRASS.  It works only for 49 files then GRASS prints a errore
> > message! Why?
> > Do you know if a mapset can accept  only 50 files ? Does the mapset have a
> > dimension limit ?
> > Help us!!
> > Thank you
> R. Joe Brandon
> Center for Advanced Spatial Technologies           (fax) 501 575-5218
> Rm. 12 Ozark Hall                                        501 575-4277
> University of Arkansas                             rjoe at cast.uark.edu
> Fayetteville, AR 72701
> Updated! -> http://www.cast.uark.edu/~rjoe
> Computers are actually powered by Chaos theory, not electricity...that
> is just for the fan.  (T. Hesser)
S.Michele 22.IV.99   Italy
Thank you for your message. The real problem was format errors in ascii data.
We've resolve them and we 're able to  import 215 files.
Now we are trying to patch them all together but r.patch allows only 10 files in
input. It is possible to change the source without create new problems?
Good bye
Valentina & Marco
