We can't import more than 49 files
Luis F. Franco
luis.franco at icp.pt
Thu Apr 22 14:55:10 EDT 1999
The program does the crossing of n maps. It uses "awk" and "r.cross" to do
the job.
Hope it helps. Good luck
Luis Franco
Instituto das Comunicações de Portugal
Av. Jose Malhoa, lt. 12
1070 Lisboa - Portugal
Phone: 351 1 7210000
Email- luis.franco at icp.pt
-----Original Message-----
From: R. Joe Brandon [mailto:rjoe at cast.uark.edu]
Sent: Thursday, April 22, 1999 7:26 PM
To: Luis F. Franco
Subject: RE: We can't import more than 49 files
I would love to see a copy of that! Thanks!
R. Joe
On Thu, 22 Apr 1999, Luis F. Franco wrote:
> Hi
> I have a script that combines a unspecified number of maps using
r.combine.
> It has an intermediate step that combines the files in groups of 10 and
then
> executes r.combine, and then combining the groups in groups of 10 again,
> running r.combine, etc... until the
> It can easily be modified to run r.patch instead of r.combine (I
think...).
> If someone wants it I can pass it to the group. I uses awk as it main
tool.
> Luís Franco
> From: Utente Grass [mailto:grass at meteux.ismaa.it]
> Sent: Thursday, April 22, 1999 11:18 AM
> To: grass at cecer.army.mil
> Subject: Re: We can't import more than 49 files
> On mer, 21 apr 1999, you wrote:
> > As far as I know GRASS has not realistic limit for the number of mapsets
> > that are allowed. I have created directories with hundreds of maps with
> > no problem. Instead could this be a disk space related error you are
> having?
> > R. Joe
> > On Wed, 21 Apr 1999, Utente Grass wrote:
> > > S.Michele 21.IV. 99 Italy
> > > We are only beginers; we created a little program to import
> automatically 215
> > > files ascii in GRASS. It works only for 49 files then GRASS prints a
> errore
> > > message! Why?
> > > Do you know if a mapset can accept only 50 files ? Does the mapset
have
> a
> > > dimension limit ?
> > > Help us!!
> > > Thank you
> > R. Joe Brandon
> > Center for Advanced Spatial Technologies (fax) 501 575-5218
> > Rm. 12 Ozark Hall 501 575-4277
> > University of Arkansas rjoe at cast.uark.edu
> > Fayetteville, AR 72701
> > Updated! -> http://www.cast.uark.edu/~rjoe
> > Computers are actually powered by Chaos theory, not electricity...that
> > is just for the fan. (T. Hesser)
> S.Michele 22.IV.99 Italy
> Thank you for your message. The real problem was format errors in ascii
> data.
> We've resolve them and we 're able to import 215 files.
> Now we are trying to patch them all together but r.patch allows only 10
> files in
> input. It is possible to change the source without create new problems?
> Good bye
> Valentina & Marco
R. Joe Brandon
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/19990422/105b3223/cross.prod.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/19990422/105b3223/all2one.reclass.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/19990422/105b3223/cross.obj
