segmentation fault with r.in.tiff
Andrew M McDermott
mcdermam at potsdam.edu
Mon Apr 26 06:36:03 EDT 1999
franzu at manhattan.unipv.it wrote:
> Hi to all Grassuser,
> I can't use r.in.tiff (nor all related scripts like r.in.arctiff)
> because it cause a Segmentation fault.
> I use Grass 4.21 with Linux-RedHat 5.2
> Any suggestion?
> TIA
> franz
Do you have the libraries (like libtif.a and all the others) required
for most programs that do conversions to/from tiff format? These might
be required by Grass to use the modules you mention (they should be
available using your Red Hat CD and the RPM) and might not be installed
by default.
