Compiling Grass 5 beta2 on RedHat6.0
Eric G . Miller egm2 at jps.net
Thu Aug 19 09:26:32 EDT 1999
Had similar problems.  With some help, I fixed some of these errors,
while someone else put together a patch.  Anyway, the patch can be found
at http://www.grasshoppernet.com/~bhughes/patch-5.0b2q-bh2.gz. I can't
say if the patch is built right, cause I fixed the sources and then
posted the changes. If that doesn't work for you, I can forward all of
the messages I previously posted on compile bugs.
On Wed, Aug 18, 1999 at 03:02:22PM +0200, Henk Coetzee wrote:
| Hi
| I installed the binary beta1 package OK, and seem to have lost the
| tarball. I have managed to download the beta2 sources, but am struggling
| to get the binaries downloaded. Our connections in South Africa often
| leave a lot to be desired. On a first attempt at installing, I get the
| following error:
| gcc -g -O2  -I/usr/local/grass5.0b/src/mapdev/Vlib
| -I/usr/local/grass5.0b/src/mapdev/diglib
| -I/usr/local/grass5.0b/src/include  -c r_dlg_head.c
| r_dlg_head.c:186: macro `strchr' used without args
| make[1]: *** [OBJ.i686-pc-linux-gnu/r_dlg_head.o] Error 1
| make[1]: Leaving directory `/usr/local/grass5.0b/src/mapdev/v.in.dlg'
| GISGEN failure at STEP: src/mapdev/v.in.dlg
| make: *** [do-install] Error 1
| How do I get around this?
| Henk
| Henk Coetzee
| Geophysics Unit
| Council for Geoscience
| Private Bag X112, Pretoria, 0001, South Africa
| Tel: +27-12-841-1192   Fax: +27-12-841-1424
Eric G. Miller
Powered by the POTATO (http://www.debian.org)!
