Bad contrast on XDRIVER24
Justin Hickey
jhickey at impact1.hpcc.nectec.or.th
Fri Aug 20 11:43:16 EDT 1999
Hello all
Some further information regarding this problem
On Aug 20, 3:20pm, Phisan Santitamnont wrote:
> Subject: Bad contrast on XDRIVER24
> Dear GRASSers,
> i have trouble with GRASS monitor when i
> display a low-contrast grey image.
> On Linux it gives only few color indexes which is
> not enogh for this kind of poor-contrast images.
> i try to switch to 'float color mode'
> and it is not possible on my LINUX
> i got message
> 'Sorry, floating color table not available on this device'
> I looked at
> $GRASSHOME/src421/src/display/devices/XDRIVER_24/lib/color_supp.c
> and saw
> #define MAX_STD_COLORS 15
We also get this message on at least 4 of our Linux boxes. But we noticed that
when we start a monitor through d.mon we get the following message:
got a TrueColor (Read-Only!) Visual
The read-only may explain why the float color mode does not work. Looking at
src/display/devices/XDRIVER_24/XDRIVER24/Clr_table.c, function
Color_table_float() has the following code at the top of the function
if (truecolor) {
return -1;
} else {
I believe the return(-1) triggers the 'Sorry, floating color table not
available on this device' error message. I partially traced it but I'm not 100%
certain.
Now in the function reset_color() located just above the Color_table_float
function there is this code at the top of the function
if (truecolor) {
/*the color table in truecolor is fixed. */
} else {
What I am wondering is whether the return(-1) can be commented out since
similar code in the same file indicates that "the color table in truecolor is
fixed". I really am not sure if commenting out this code will truly solve the
problem since other problems could appear. Also, Dr. Phisan's findings may also
solve the problem.
Does anyone with knowledge of this code know the correct way to fix this
problem?
Thank you for your time and effort in this matter.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
