Grass5.0beta2 install prob with binaries
bob at math.umn.edu
bob at math.umn.edu
Mon Aug 23 15:56:40 EDT 1999
> On Fri, Aug 20, 1999 at 03:47:38PM -0500, bob at math.umn.edu wrote:
> > Ideally the
> > lock files would instead be in the user home directory, maybe in some
> > place like ~/.grass, as with Netscape and other utilities. This
> > might (again, if I understand enough grass) make the installation more=20
> > secure. And there seem to be a number of lock and other little files
> > floating about.
> Some lockfiles have to be global, just think of the number of
> graphic display pipes used or physical inputs devices.=20
> So two ways from there to improve the situation:
> Make the locking executables setgid or setuid.
> (and have just one executable doing the locking.)
> And/or use the /tmp directory.
> Localise all global lockable resources.
> (Unlikely to work.)
> Bernhard
OK. This looks, then, like a situation which is dependant on the local
environment. With xterms off a central server I can see the problems.
With a bunch of networked PCs (what we have here) it may be less of a
difficulty.
I would not like to have the executables be more "powerful," so localizing
locks would be a better solution. Perhaps this could eventually be a
configuration option. Of course, there likely are more important things
to worry about. :^)
Thanks for your time.
Adios,
Chris
C.S. Cornuelle
School of Mathematics/MCIM
206 Church St. SE
University of Minnesota
Minneapolis, MN 55455
(612) 626-8930, 624-9069
bob at math.umn.edu
Ferventer Vestite
