raster integer *3 ?
Malcolm Williamson
malcolm at cast.uark.edu
Tue Dec 14 09:38:11 EST 1999
Hi, Agus!
I don't really have an answer to your problem, but I wanted to comment
on it. I always considered it a plus that GRASS used only the minimum
number of bytes necessary (1, 2, 3, or 4) to store its raster data. When
converting to Intergraph's raster format, file size often grew
considerably due to being forced to long int.
Truth is, I guess I'm usually more interested in importing data to
GRASS, rather than exporting from GRASS! :)
Best regards,
-Malcolm
Malcolm D. Williamson malcolm at cast.uark.edu
Center for Advanced Spatial Technologies Voice: 501-575-2734
12 Ozark Hall Fax: 501-575-5218
University of Arkansas, Fayetteville AR 72701
http://www.cast.uark.edu/
Agustin Lobo wrote:
> Hi!
> I'm exporting a Grass raster to another
> software. I'm surprised by the fact
> that the raster is 321x414x3 bytes.
> Normally, it should be either 321x421x2 or
> 321x414x4.
> Besides using r.mapcalc and transforming it
> to float, is there any way to pass it
> to int*4 (long integer)?
> Thanks
> Agus
> Dr. Agustin Lobo
> Instituto de Ciencias de la Tierra (CSIC)
> Lluis Sole Sabaris s/n
> 08028 Barcelona SPAIN
> tel 34 93409 5410
> fax 34 93411 0012
> alobo at ija.csic.es
> http://pangea.ija.csic.es/alobo
Best regards,
-Malcolm
