Grass on MkLinux Problem
Ben Horner-Johnson
ben at earth.nwu.edu
Mon Feb 1 13:25:42 EST 1999
> Try running grass as the user that logged in. If you prefer for other
> reasons, you could try the xhost command, which describes to the X display
> who can put a window up. To make it open to anyone (Yes- don't do this,
> it's a security risk over the long term) try the command "xhost +" by the
> logged-in user.
A safer thing is to run xhost + your.hostname, which releases access control
of your screen to anyone logged in to your machine, but not the entire world.
Ben Horner-Johnson
