Q: vector map patching
Alejandro Hinojosa Corona
alhinc at cicese.mx
Mon Jan 11 12:43:01 EST 1999
Markus,
You can use first the v.cutter to extract the less
quality data with a vector that has the extents of your
good quality data and then use v.patch to overlay the good qual
Regards
Alejadnro Hinojosa
> Hi,
> currently I have the problem to merge a small vector map
> in good digitizing quality and a second in less quality.
> The small one is part of the second - I want to *replace*
> a part of the map with less quality by overlaying this
> small map:
> |less qual. |
> | |good| |
> | |qual| |
> How to perform such replacement in GRASS? I feel that v.patch
> will just overlay both maps.
> Thanks for assistance
> Markus
