snapping areas in v.digit
    Alexandre Rodier
    alexrod at fcu.um.es
    Wed Jan 20 11:32:29 EST 1999
Dear Juergen
When you are digitizing an areas map you don't need to repeat adjacent lines.
You must digitize the common border only one time, and snap the two nodes.
You can make you an idea with the attached image (sorry it's in spanish).
In all cases you must closed the area, normally opened nodes are green, and closed
nodes red, so you can easely find whats nodes are bad. You have the possibility to
snap automatically snap nodes with v.support.
Be carefull with this option, because you must check the right minimum distance
between two opened nodes.
If the distance is too large, v.support will snap all areas together.
I hope it'll help you
Juergen wrote:
> Hi all,
> I try to digitize a soil map with v.digit. The areas, which lay side by side are
> using the same line as a common border.
> How do I manage to digitize these areas without digitizing each line a second
> time for the adjacent areas? Can I snap one area with with another open area to
> get two closed polygons?
> Thanks in advance
>         Juergen Rogozia
Alexandre Rodier
    INUAMA
Universidad de Murcia
Campus de Espinardo
30100 - MURCIA -
   - SPAIN -
tel: -34 968.36.48.45
alexrod at fcu.bio.um.es
Type: image/gif
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/19990120/12cc1d83/nodo.gif
