New GIS.sh (bash shell/GRASS problem)
Markus Neteler
neteler at geog.uni-hannover.de
Sat Jan 23 11:42:50 EST 1999
I have changed the etc/GIS.sh file to fix the bash problem
(there was no GRASS modules access due to path problems).
When you have such a problem, replace the GIS.sh file
in grass42/etc with the attached file (please make savety
copy of the original file). You can find it also on
GRASS 4.2.1 faq:
http://www.geog.uni-hannover.de/grass/grass_faq.html
I have added a "bash" section to GIS.sh, and tested it on
SuSe 5.3/bash.
Hope this helps
Markus Neteler
: ${GISBASE?}
# get home directory, name of lockfile and gisrc file
home=`cd;pwd`
lockfile=$home/.gislock
GISRC=$home/.grassrc
export GISRC
# set the GIS_LOCK variable to current process id
GIS_LOCK=$$
export GIS_LOCK
# set PATH to GRASS bin, ETC to GRASS etc
ETC=$GISBASE/etc
PATH=$GISBASE/bin:$GISBASE/scripts:$GISBASE/garden/bin:$PATH
export PATH
# check for concurrent use
$ETC/lock $lockfile $$
case $? in
0) ;;
1)
echo `whoami` is currently running GRASS. Concurrent use not allowed.
exit ;;
echo Unable to properly access $lockfile
echo Please notify system personel.
exit ;;
esac
# first time user ...
if [ ! -f $GISRC ]
then
cat $ETC/gis_intro
echo ""
echo "Hit RETURN to continue"
read ans
fi
# user selects LOCATION and MAPSET
$ETC/gis_set
case $? in
0) ;;
*) exit ;;
esac
# unset the MONITOR variable to force user to select one if they are going
# to do graphics.
g.gisenv MONITOR=
# get gisrc into the environment
eval `g.gisenv`
LOCATION=${GISDBASE?}/${LOCATION_NAME?}/${MAPSET?}
export LOCATION
if [ -x $home/.grassrc.4.2.1 ]
then
elif [ -x $GISBASE/grassrc ]
then
$GISBASE/grassrc
fi
trap "" 2 3
sh="`basename $SHELL`"
case "$sh" in
ksh) shellname="Korn Shell";;
csh) shellname="C Shell" ;;
tcsh) shellname="TC Shell" ;;
bash) shellname="Bash Shell" ;;
sh) shellname="Bourne Shell";;
*) shellname=shell;;
esac
# Display the advertising
clear
cat << EOF
Welcome to GRASS 4.2.1 (V.20 - December 1998)
Geographic Resources Analysis Support System (GRASS) is a Trademark
of U.S. Army Construction Engineering Research Laboratories (USACERL)
and Baylor University GRASS Research Group.
This new release of GRASS is coordinated and produced by the GRASS
Research Group at Baylor University with assistance from the Office
of GRASS Integration (OGI) located at USACERL.
This version running thru the $shellname ($SHELL)
Help is available with the command: g.help
When ready to quit enter: exit
EOF
case "$sh" in
csh|tcsh)
HOME=$LOCATION
export HOME
cshrc=$HOME/.cshrc
tcshrc=$HOME/.tcshrc
rm -f $cshrc $tcshrc
echo "set home = $home" > $cshrc
echo "set history = 30 noclobber ignoreeof" >> $cshrc
echo "set prompt = '\\" >> $cshrc
echo "Mapset <${MAPSET}> in Location <${LOCATION_NAME}> \\" >> $cshrc
echo "GRASS 4.2.1 > '" >> $cshrc
echo 'set BOGUS=``;unset BOGUS' >> $cshrc
if [ -r $home/.grass.cshrc ]
then
cat $home/.grass.cshrc >> $cshrc
fi
if [ -r $home/.cshrc ]
then
grep '^ *set *mail *= *' $home/.cshrc >> $cshrc
fi
if [ -r $home/.tcshrc ]
then
grep '^ *set *mail *= *' $home/.tcshrc >> $cshrc
fi
if [ -r $home/.login ]
then
grep '^ *set *mail *= *' $home/.login >> $cshrc
fi
echo "set path = ( $PATH ) " | sed 's/:/ /'g >> $cshrc
cp $cshrc $tcshrc
$ETC/run $SHELL
HOME=$home
export HOME
bash)
HOME=$LOCATION # save .bashrc in $LOCATION
export HOME
bashrc=$HOME/.bashrc
rm -f $bashrc
echo "test -z $PROFILEREAD && . /etc/profile" > $bashrc
echo "test -e ~/.alias && . ~/.alias" >> $bashrc
echo "umask 022" >> $bashrc
if [ -r $home/.grass.bashrc ]
then
cat $home/.grass.bashrc >> $bashrc
fi
echo "export PATH=$PATH" >> $bashrc
$ETC/run $SHELL
HOME=$home
export HOME
PS1="
Mapset <$MAPSET> in Location <$LOCATION_NAME>
GRASS-GRID > "
export PS1
$ETC/run $SHELL
esac
trap 2 3
monitor=`g.gisenv MONITOR`
if [ "$monitor" ]
then
$ETC/mon.release -v $monitor
fi
g.gisenv MONITOR=
# Read gisrc again
eval `g.gisenv`
# exit session. remove unwanted files
clear
echo ""
echo "GRASS SESSION WRAPUP"
echo ""
echo "You have just finished working on mapset: <$MAPSET>"
echo ""
any=no
dir=$LOCATION/cell
type=RASTER
count=0
if [ -d $dir ]
then
count=`ls $dir | wc -l`
fi
if [ $count != 0 ]
then
any=yes
echo ""
echo "The following $type maps belong to it:"
ls -C $dir | awk '{print " " $0}'
echo ""
else
echo "There are no $type maps in this mapset"
fi
dir=$LOCATION/dig
type=VECTOR
count=0
if [ -d $dir ]
then
fi
if [ $count != 0 ]
then
any=yes
echo ""
echo ""
else
fi
dir=$LOCATION/site_lists
type=SITES
count=0
if [ -d $dir ]
then
fi
if [ $count != 0 ]
then
any=yes
echo ""
echo ""
else
fi
echo ""
if [ $MAPSET != PERMANENT ]
then
$GISBASE/etc/echo -n "Shall the mapset <$MAPSET> be saved? y/n [y]"
read ans
else
ans=YES
fi
case $ans in
n|no|N|NO|No)
echo ""
echo "WARNING - if you remove your mapset, you will lose"
echo " all your data files in this mapset"
echo ""
$GISBASE/etc/echo -n "are you sure you want to remove your mapset? y/n [n]"
read ans
case $ans in
y|yes|Y|YES|Yes)
echo ""
echo "Removing MAPSET $MAPSET"
rm -rf $LOCATION
if [ -d $LOCATION ]
then
echo "WARNING: Unable to completely remove $LOCATION"
else
echo "MAPSET --$MAPSET-- REMOVED."
fi
sleep 3 ;;
esac
if [ $any = yes ]
then
echo ""
$GISBASE/etc/echo -n "Do you wish to selectively remove data files? y/n [n]"
read ans
case $ans in
y|yes|Y|YES|Yes)
$GISBASE/bin/g.remove ;;
esac
fi
($ETC/clean_temp > /dev/null &)
esac
clear
echo ""
echo ""
echo ""
echo " GOOD BYE from GRASS"
rm -f $lockfile
echo ""
echo ""
