SG3D
Michael Schulz
schulzm at perm.geologie.uni-freiburg.de
Thu Jan 28 04:58:15 EST 1999
Hi !
We have SG3d and gl3d also installed on the SGI´s. But there is a version
of gl3d that should run under OpenGL. We have not tested it, but you will
find it under http://www.cecer.army.mil/grass/viz/sg3d.html and then
proceed to the ftp-directory of ogl3d.
The gl3d we use, has several known bugs, but it is much more powerful
than SG3d, you can for example display several elevation layers, like
with the coming nviz tool (in fact gl3d looks the same and you can use
the nviz-tutorial also for gl3d).
Good luck!
Michael
Michael Schulz
Christoph-Mang-Str.5 Geologisches Institut
79100 Freiburg Universitaet Freiburg
Albertstr. 23b
79104 Freiburg
On Wed, 27 Jan 1999, Michel Wurtz - LTE wrote:
> I am *very* interested by SG3D... but have no SGI computer :-(
> Does anyone tested it with the MesaGL library ? Or is SG3d too
> dependant of the SGI hardware ?
> Michel Wurtz ENGEES - Laboratoire Territoires & Environnement
> 1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
> Tel: +33 03.88.24.82.45 Fax: +33 03.88.37.04.97
