GIS.sh update again
Markus Neteler neteler at geog.uni-hannover.de
Fri Jan 29 09:16:43 EST 1999
some people reported a DISPLAY-variable problem. I have
added the specific line to the bash part of GIS.sh.
Store this file to
grass4x/etc/GIS.sh
You need, even if you have a stand-alone machine, to configure
your network to "local loopback" or similar. It must be configured
into working condition.
Hope this helps
Markus
: ${GISBASE?}
# get home directory, name of lockfile and gisrc file
home=`cd;pwd`
lockfile=$home/.gislock
GISRC=$home/.grassrc
export GISRC
# set the GIS_LOCK variable to current process id
GIS_LOCK=$$
export GIS_LOCK
# set PATH to GRASS bin, ETC to GRASS etc
ETC=$GISBASE/etc
PATH=$GISBASE/bin:$GISBASE/scripts:$GISBASE/garden/bin:$PATH
export PATH
# check for concurrent use
$ETC/lock $lockfile $$
case $? in
 0) ;;
 1)
    echo `whoami` is currently running GRASS. Concurrent use not allowed.
    exit ;;
    echo Unable to properly access $lockfile
    echo Please notify system personel.
    exit ;;
esac
# first time user ...
if [ ! -f $GISRC ]
then
	cat $ETC/gis_intro
	echo ""
	echo "Hit RETURN to continue"
	read ans
fi
# user selects LOCATION and MAPSET
$ETC/gis_set
case $? in
 0) ;;
 *) exit ;;
esac
# unset the MONITOR variable to force user to select one if they are going
# to do graphics.
g.gisenv MONITOR=
# get gisrc into the environment
eval `g.gisenv`
LOCATION=${GISDBASE?}/${LOCATION_NAME?}/${MAPSET?}
export LOCATION
if [ -x $home/.grassrc.4.2.1 ]
then
elif [ -x $GISBASE/grassrc ]
then
	$GISBASE/grassrc
fi
trap "" 2 3
sh="`basename $SHELL`"
case "$sh" in
    ksh)  shellname="Korn Shell";;
    csh)  shellname="C Shell" ;;
    tcsh) shellname="TC Shell" ;;
    bash) shellname="Bash Shell" ;;
    sh)   shellname="Bourne Shell";;
    *)    shellname=shell;;
esac
# Display the advertising
clear
cat << EOF
Welcome to GRASS 4.2.1 (V.20 - December 1998)
Geographic Resources Analysis Support System (GRASS) is a Trademark
of U.S. Army Construction Engineering Research Laboratories (USACERL)
and Baylor University GRASS Research Group.
This new release of GRASS is coordinated and produced by the GRASS
Research Group at Baylor University with assistance from the Office
of GRASS Integration (OGI) located at USACERL.
This version running thru the $shellname ($SHELL)
Help is available with the command: g.help
When ready to quit enter:           exit
EOF
case "$sh" in
csh|tcsh)
    HOME=$LOCATION
    export HOME
    cshrc=$HOME/.cshrc
    tcshrc=$HOME/.tcshrc
    rm -f $cshrc $tcshrc
    echo "set home = $home" > $cshrc
    echo "set history = 30 noclobber ignoreeof" >> $cshrc
    echo "set prompt = '\\" >> $cshrc
    echo "Mapset <${MAPSET}> in Location <${LOCATION_NAME}> \\" >> $cshrc
    echo "GRASS 4.2.1 > '" >> $cshrc
    echo 'set BOGUS=``;unset BOGUS' >> $cshrc
    if [ -r $home/.grass.cshrc ]
    then
	cat $home/.grass.cshrc >> $cshrc
    fi
    if [ -r $home/.cshrc ]
    then
	grep '^ *set  *mail *= *' $home/.cshrc >> $cshrc
    fi
    if [ -r $home/.tcshrc ]
    then
	grep '^ *set  *mail *= *' $home/.tcshrc >> $cshrc
    fi
    if [ -r $home/.login ]
    then
	grep '^ *set  *mail *= *' $home/.login >> $cshrc
    fi
    echo "set path = ( $PATH ) " | sed 's/:/ /'g >> $cshrc
    cp $cshrc $tcshrc
    $ETC/run $SHELL
    HOME=$home
    export HOME
bash)
    HOME=$LOCATION      # save .bashrc in $LOCATION
    export HOME
    bashrc=$HOME/.bashrc
    rm -f $bashrc
    echo "test -z $PROFILEREAD && . /etc/profile" > $bashrc
    echo "test -e ~/.alias && . ~/.alias" >> $bashrc
    echo "umask 022" >> $bashrc
    if [ -r $home/.grass.bashrc ]
    then
	cat $home/.grass.bashrc >> $bashrc
    fi
    echo "export PATH=$PATH" >> $bashrc
    $ETC/run $SHELL
    HOME=$home
    export HOME
PS1="
Mapset <$MAPSET> in Location <$LOCATION_NAME>
GRASS-GRID > "
    export PS1
    $ETC/run $SHELL
esac
trap 2 3
monitor=`g.gisenv MONITOR`
if [ "$monitor" ]
then
	$ETC/mon.release -v $monitor
fi
g.gisenv MONITOR=
# Read gisrc again
eval `g.gisenv`
# exit session. remove unwanted files
clear
echo ""
echo "GRASS SESSION WRAPUP"
echo ""
echo "You have just finished working on mapset: <$MAPSET>"
echo ""
any=no
dir=$LOCATION/cell
type=RASTER
count=0
if [ -d $dir ]
then
    count=`ls $dir | wc -l`
fi
if [ $count != 0 ]
then
    any=yes
    echo ""
    echo "The following $type maps belong to it:"
    ls -C $dir | awk '{print " " $0}'
    echo ""
else
    echo "There are no $type maps in this mapset"
fi
dir=$LOCATION/dig
type=VECTOR
count=0
if [ -d $dir ]
then
fi
if [ $count != 0 ]
then
    any=yes
    echo ""
    echo ""
else
fi
dir=$LOCATION/site_lists
type=SITES
count=0
if [ -d $dir ]
then
fi
if [ $count != 0 ]
then
    any=yes
    echo ""
    echo ""
else
fi
echo ""
if [ $MAPSET != PERMANENT ]
then
    $GISBASE/etc/echo -n "Shall the mapset <$MAPSET> be saved? y/n [y]"
    read ans
else
    ans=YES
fi
case $ans in
    n|no|N|NO|No)
	echo ""
	echo "WARNING - if you remove your mapset, you will lose"
	echo "          all your data files in this mapset"
	echo ""
	$GISBASE/etc/echo -n "are you sure you want to remove your mapset? y/n [n]"
	read ans
	case $ans in
	    y|yes|Y|YES|Yes)
		echo ""
		echo "Removing MAPSET $MAPSET"
		rm -rf $LOCATION
		if [ -d $LOCATION ]
		then
		    echo "WARNING: Unable to completely remove $LOCATION"
		else
		    echo "MAPSET --$MAPSET-- REMOVED."
		fi
		sleep 3 ;;
	    esac
	if [ $any = yes ]
	then
	    echo ""
	    $GISBASE/etc/echo -n "Do you wish to selectively remove data files? y/n [n]"
	    read ans
	    case $ans in
		y|yes|Y|YES|Yes)
		    $GISBASE/bin/g.remove  ;;
	    esac
	fi
	($ETC/clean_temp > /dev/null &)
esac
clear
echo ""
echo ""
echo ""
echo "                  GOOD BYE from GRASS"
rm -f $lockfile
echo ""
echo ""
